Results 1 to 8 of 8
Thread: How To Change Calibration for L/100km and Trip Distance??
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    Default How To Change Calibration for L/100km and Trip Distance??
    Does anyone know how to calibrate the amount of fuel used for a perticular fill up. also the trip distance calibration. i used to do these on the VT but cant seem to find it on the VZ. ultimately doing these will make my speedo correct and the L/100km more accurate.
    [ASLYVY] is offline DavidP
    2006 VZ Executive
    May 2006
    Hoppers Crossing
    Quote Originally Posted by holdenvtman1123 View Post
    In the VZ if you hold down "SET" FIRST as well as the "UP AND DOWN" Buttons while on your Trip mode on the speedo this will reset your trip to 0.00km as well as reset your L/100km and give you a reading according to the current trip.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Does this help?
    Applies to VZ Calais with triple window speedo.
    Attached Files Attached Files
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Execcies cant do it unfortunately, you need a triple window cluster like berlina or calais
    Sep 2008
    Broken Hill NSW
    hmm bummer, im running the original size wheels and the speedo is out 2-3 km per hour. maybe tech-2 can do it?
    VZ Berlina
    Jan 2010
    Caringbah, Sydney
    out as in the in actual speed at an indicated say 100km/h is really 97km/h?
    this is in just about every car, think its manufacturers way of overing their ass kinda thing..
    motor used to do a speed at indicated 100km/h in their test's..most cars were 3 or more km/h under indicated speed.
    JBDrifter's Avatar
    JBDrifter is offline Now in a Calais
    VZ Calais & VT Exec Wagon
    Oct 2006
    Quote Originally Posted by DAZ88P View Post
    My speedo is out by about the same amount too, and always put it down to the reason you just gave. But I've always wondered whether this difference has an effect on the odometer? My speedo seems to be about 3 or 4 percent above my actual speed (used GPS to find actual speed), so is my odometer 3 or 4 percent higher than the actual km's it's been driven?
    Sep 2008
    Broken Hill NSW
    the book says it doesnt alter the odometer just the trip and fuel consumption
  1. VXII Trip Computer Calibration
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 09:14 PM
  2. Trip Computer Calibration
    By mutley87 in forum General
    Last Post: 08-09-2005, 08:49 PM
  3. VR 5L trip comp calibration
    By BathurstVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2005, 05:27 PM
  4. VS Berlina trip comp calibration
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2005, 09:09 PM
  5. Vs Trip Computer Calibration
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2004, 12:28 AM
