Results 1 to 24 of 24
Thread: Alloytech stuff up
    VZ executive
    Feb 2009
    warragul
    Angry Alloytech stuff up
    I just found out the slight knocking noise in my 175kw motor is the timeing chain, apparently it's a build defect by Holden that the vz motors are fitted with the wrong size timeing chain and is only noticeable when the cars hit 130000km, annyone heard of this and how much it might cost to repair thanks guys
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Yeah, I've heard abit about it. Was the reason why I bought an older car like the VX instead of getting the missus a VZ or even a VE.
    Drove a few low-spec VE's and I have to say I wasn't impressed what-so-ever
    VE SV6 ute
    Apr 2009
    vic
    Quote Originally Posted by neet_wagon View Post
    What does any of this have to do with his question?
    Jan 2010
    Bendigo, Victoria
    Quote Originally Posted by kuzman89 View Post
    The build defect he was referring to. I fail to see how some of the people on here got thier license, when they struggle to put two and two together......
    VE SV6 ute
    Apr 2009
    vic
    I fail to see how you got your license when you can't even spell 'thier' properly.
    Your post had zilch relevance to the question he was asking. The early vz's were the only cars with this problem, the ve had no such problems.
    VX II Calais L67 Manual 17 PSI W2A + MAFLESS
    Apr 2009
    Hey Mate,
    Did you have any luck sorting out the issue? Have heard of the same issue on a few alloytecs now which is a shame.
    Good luck, hope you get it sorted soon.
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    No need to fix it. Mines has bad timing chain rattle on startup since i got the car with 90k the clock. The problem was fixed in the VE's btw.
    VZ Adventra SX6
    May 2009
    Yep.. Just got mine replaced (lucky under warranty).
    There is a fault with in the early models of the alloytec. Mine is the 190, not the 175.
    I was told that is is a known fault at Holden and they hope people let it go and not get it fixed until too late (I personaly think it should have a recall on it). They said not getting it fixed, will cause major damage from the 150000km.
    I was told there is a modification to the timing change components (which as mentioned above is fixed in later versions). Because of these modifications, they had to change the oil pump and other components.
    Dont worry too much as the chain wont snap (not like a timing belt) but you will progressively start to loose power. On long runs (20Km+), once it was warmed up, I found that I hardly had any power from the engine.
    Just my 2 cents worth. Like I said most of the info above, I was told about.. I'm no expert though.
    Rob
    Edit: Mine had only done 85000KM
    Mar 2009
    Quote Originally Posted by rb0135 View Post
    T They said not getting it fixed, will cause major damage from the 150000km.
    Mate a loose timing chain will not cause any damage (unless it snaps, ive had timing chains snap on me before!!!) or loose ANY power to the motor lol. The only downside is the noise which is a little embarrassing on such a new car.
    My timing chain is loud as hell and the car has been on the dyno and made good power ect. Out of curiosity how much do Holden quote to have the fault with the timing chain fixed??
    VZ Adventra SX6
    May 2009
    Well, I have proof that I lost power because of it, and the Techline article states that, but i wont argue about it.. it was fixed and there is a difference.
    Its not actually a loose timing chain that is the fault. It is another component that causes the fault, including the chain. If you are interested, i can always pull out the service card and see if it states what was replaced.
    As mine was under warranty, I didnt find out the cost, but because they had to strip most of the front of the engine down (they had to replace more than a timing chain), it took over 2 days to complete (probably the apprentices were doing it) and that would probably amount to a lot just in Labour Costs (specially delaership costs).
    Rob
    Mar 2009
    Rob
    Fair enough where is the proof out of curiosity?
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Mine's done 130,700kms. No problems to report. I looked through the workshop manual, there are no recalls or build faults related to the timing chain. The yanks would've sorted the problem out before selling the motor to Holden anyway.
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Rob
    You got something against apprentices? Most jobs are done better by apprentices because they follow the book. Most mechanics will do something their own way and might miss important details. Sure, the hours are longer, but the job is done to the letter.
    I'm only 2 months into my diesel mechanic apprenticeship, and I'm already doing a rebuild on a truck engine. I'm following procedure by the book and asking if I have any problems. The job is not rushed, and the customer can sleep easy.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Quote Originally Posted by VzVzVz View Post
    Good on you for having a go. Hopefully your employer only charges customers an hourly rate to cover the cost of an apprentice, NOT the full going rate for a qualified mewchanic !!
  15. #15
    VZS-Ute06
    Aug 2006
    Western Vic
    Red face
    Never had an issue and mine's just cranked over 150K
    motor still feels fresh n' tight
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
  16. #16
    supercellkid is offline Banned
    06 VZ Calais LY7
    Jan 2010
    near geelong, victoria
    Once upon a time before I had enough money to buy my VZ calais, I had a 1997 Saab CD xxxx (cant remeber model numbers) It was an ok car apart from huge costs of repair (being euro).
    There was a rattling / knocking coming from engine. I did the Handle of screw driver in ear thing (to use like stethoscope) and was relatively certain it was the timing chain.
    One day while driving behind someone who was doing 60k in a 70k zone I got shitti and dropped from 4th to 2nd and engine would have hit roughly 5500rpm. While about midway through the overtake maneuver there was a very slight bang/loud knock and the engine went dead.
    RACV towed me to the nearest Saab specialist (only one in Geelong) it was quickly determined that the timing chain had snapped (they will do this when loose, esp @ high RPM) (all I had to do was adjust the tensioner as it was an adjustable type)
    So anyway, apparently with modern high output motors, esp those with high comp rations of 9:1 or greater the clearance between the piston tops and the bottom of the valves is very little, in fact they go beyond each other except they are timed to miss. So when or If your Cam suddenly;y stops turning because timing chain snapped (esp at high RPM) your crank will or rather can continue to turn for up to 2 or 3 seconds. In turn your pistons will continue to suck, squeeze, bang, blow. (thanks Mr Adams Newport TAFE) therefore your piston tops will have intercourse with the bottoms of your valves, thus bending every single one of them.
    I can only imagine its the same with the Alloy tech as I have never had that prob with my VZ alloytech 190 (knck on wood) /me knocks on head. (now at 151,000Km (im a storm chaser))
    So if it turns out that the Timing chain cannot be tightened by adjusting the Timing chain Tensioner then you MUST REPLACE the chain or you are up for many more dollars that $520.If it does Snap. Now if your concerned that I might not know what Im talking about, at least with the alloy tech, just ask your local Alloy tech expert. As in someone who is likely to have seen it all. Surely they will have come across Snapped Timming chains before. Ask them was there other damage caused after timing chain snapped.
    BTW the SAAB dealer wanted $4500 to fix my saab motor. Turns out my brother in law was very good with Euro cars like Merc, Jag, BMW and esp Volvo. He quoted me $1500 of which $1400 was paid up front. He ended up not doing the work. Instead he said that I owed him for fines (not true) and the hire of $500 bombs he had loaned me while I waited almost a year for him to fix. In other words he was coming up with every bull dust excuse he could find to get out of doing it or paying me back.
    The moral of that part is never EVER pay up front. I did coz 1) he was family, and 2) I felt sorry for him, as he (apparently) had been giving alot of credit to single mums and crap, and was broke)( oh yeah and he didnt even ask for money up front). I later find out he is a compulsive liar. Im worried if I say his name ill get in some kind of crap esp after all the defamation crap Ii have been hearing about on the news with re to Facebook and the like. Anyone know if I can legally say his name? Coz I would hate for him to work on any of you guys cars? Its not a bad idea to get feedback or reviews before undertaking large amounts of money to an unknown motor mech.
    How do I hack TCS on my VZ calais? I want a little sideways action (please post me a oood link)
  17. #17
    05 VZ Equipe
    Mar 2011
    Melb
    Oh no mines at 63,XXX Km's, im not looking forward to this potential problem...
  18. #18
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    i have an 04 model, i have hit 156xxx and i have noticed from the first time i bought it (100,000), there was a noise at startup for about 2 sec, but never had any problems with the car. a little leaking from the waterpump i observed a few thousand k ago, but after i cleaned it off with degreaser, i have not seen any leaks yet. as far as im aware, the vz is a good engine, and the only downfall is in performance modifications. but as i said, 156xxx km and still going strong, and im not a light driver either, i do push the limits and never skipped a beat.
    Spoken by a true member of The Committee
  19. #19
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    I have nothing against apprentices, everyone's gotta learn somehow, but this made me chuckle.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  20. #20
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    I am a heavy diesel apprentice, so i know what i'm talking about. Apprentices make more dumb mistakes than tradesmen, but a tradesman may let something go because its not on the job sheet or its not broken yet.
    Happens every day, not good when you ignore a safety problem on council buses. Some tradesman treat the vehicle as their own, others don't care.
    But i would still rather have a tradesman work on my car, sorry VzVzVz.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
  21. #21
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    VE's can suffer the same problem also. Along with models in the US with a similar engine.
    There was a post in the VE section recently on this issue.
    Holden are charging upwards of $2000 to fix.
  22. #22
    Little Red VZ Go-Kart's Avatar
    Little Red VZ Go-Kart is offline Middle-age mutant ninja
    Ex-CFA VZ 175 Commodore Exec. 06 wagon
    Aug 2010
    Democratic People's Republic of Highton / Geelong
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    VE??? The Omega models? Friend's 2010 VE Omega (company car) makes a brief "clacking" sound when starting up. This is curious. It's only done 39,000km, but has been absolutely thrashed — I certainly wouldn't drive my car where I've been in his (despite the mirth and horror...). Shows you what happens when people have company cars and not too interested in looking after them... Timing chains, tapsters or his steel-toed boot tapping to "Reservoir Dogs"??
    •:*¨¨*:•.When you start your car, does it return the favour? •:*¨¨*:•.
    Originally posted by soop
    Your arse is going to sting for a while, and then worse when it does bugger all.
  23. #23
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Selling the motor to Holden? isnt the alloytec a aussie motor made at the melbourne engine factory?
  24. #24
    VZ A4 Saloon
    Nov 2010
    Quote Originally Posted by 1_johnboy View Post
    Yes. Also co-engineered by Holden.
  1. [VIC] Heaps of VT - VX stuff, a few headunits and stuff
    By GILLO in forum Parts And Other Items For Sale
    Last Post: 21-09-2009, 02:41 AM
  2. Smits Cleanout Sale (VT-VX Stuff, Other random stuff)
    By SMIT in forum Parts And Other Items For Sale
    Last Post: 05-03-2008, 10:43 PM
  3. alloytech v6
    By sv9946 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2007, 06:54 AM
  4. F.S. heaps of vk stuff. 308's ect ect ect some 6 cly stuff too!!
    By ported in forum Parts And Other Items For Sale
    Last Post: 10-05-2007, 07:36 PM
  5. 190 kw Alloytech V6!!!
    By Wombat in forum General
    Last Post: 29-07-2004, 08:50 AM
