Results 1 to 11 of 11
Thread: VZ squeaking drive belt solution
    VZ Calais
    Jul 2009
    Default VZ squeaking drive belt solution
    If you have a belt that squeaks or squeals then if could be caused by a couple of things - most often a stuffed belt, or not so often a damaged pulley (bearings usually).
    A quick way to tell how bad the problem is, is to liberally squirt the BELT ONLY with silicone spray while the engine is running. Spray onto the top (flat) side of the belt and try to avoid getting any on the pulleys. This will tell you very quickly whether it is the belt only or whether there are other problems too...
    If the squeaking is still there after the belt has been sprayed, try spraying the pulleys one at a time, starting with the 2 small-ish idler pulleys in the centre of the engine. Once you figure out which one is causing the noise then it can be replaced.
    VZ Calais
    Nov 2008
    Melbourne, Victoria
    See I have this same problem but replacing the belt 3 times has done nothing. However when I squirt a silicon spray just onto the belt the problem goes away, and then promptly comes back the next day. It's gotten to the point where, just to get some peace and quiet, I've covered the whole belt in Armorall and that shuts it up for weeks.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by whitey5759 View Post
    Yeah but its going to get to the point where the belt will start to slip cause ur using a silicon based cleaner.
    To the OP have u checked the idler pulley tension?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VX HSV GTS
    Apr 2006
    Tas
    If you have fitted an U/D pulley to your car the A/C belt is also prone to squeal.
    2 of the fixes for this is use a slightly smaller belt, or replace the belts with the bosch brand and bobs your uncle!
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Quote Originally Posted by PaulSV6 View Post
    You are so correct. Nearly all of the "solutions" I have seen on this site for the belt noise involve lubrication of the belt in one form or another such as we have above - including ArmorAll and like substances.
    I would much rather the belt noise than produce a slipping serpentine belt.
    VZ SV6
    Sep 2009
    Wingham, Mid North Coast, NSW
    mine was doing this for a while, used wd40 did its bit here & there but i just got over buyin it all the time
    after a while it simply dissapeared, just live with it for a week or 2 & mine was fine
    When in the chicken coup, if i wanna get lucky, i get clucky clucky
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    Quote Originally Posted by colgf View Post
    Does Armorall work on a wife like that ????
    PMSFL
    Sep 2007
    VZ Calais
    Jul 2009
    2000 vt executive
    Mar 2010
    mine did the same it was a repco belt went to holden and repco belt slightly smaller put genuine one on and no dramas
  1. Squeaking Drive Belt VS V6 commodore
    By Changa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2012, 10:04 PM
  2. drive belt
    By Simonn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2009, 09:40 PM
  3. Drive Belt.
    By Tam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 07:49 PM
  4. Drive belt ?
    By BLACK-2002 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 09:38 AM
  5. Drive belt gone?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 11:05 AM
