Results 1 to 11 of 11
Thread: Hesitation / thump /miss when accelerating from 80km/h
    VZ
    Feb 2009
    Default Hesitation / thump /miss when accelerating from 80km/h
    Hello all,
    Last night we took a 4 hour trip in our 2005 VZ (105,000 km) when accelerating from 80km/h back up to 100km/h, we noticed a miss and an almost a thumping when the accelerator was pushed down. When it did get back up to the 100km/h speed it seemed fine. Any ideas what we should be looking for? - i'm suspecting crook leads but just wanted to know if anyone else has experienced this.
    Many thanks in advance.
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    it is quite possibly the cranckshaft balance wheel. check the rubber around the center of the pulley
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Quote Originally Posted by holdenvtman1123 View Post
    il second tht coomon prob those harmonics
    VP Calais 3.8L
    Jan 2006
    Ringwood, Vic
    Harmonic balancer shouldn't have worn after 5 years..
    Or are they really problematic with VZ's?
    Plus if it's so gone as to cause problems you would probably hear it (like a ****ed bearing).
    From my experience anyway
    VZ SENATOR
    Mar 2009
    I had a similar issue with my VZ that started around the 100,000k mark... It turned out to be the ignition coils which were not firing the spark plugs properly and causing a miss.
    This only happened when using medium to heavy acceleration or trying to build up speed (say from 80-100) in 5th gear.
    Hope this helps.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    ive never heard off balancer problems on alloytecs, the crank signal does not run off the alloytec balancer either,
    id be leaning towards coils, seems to be a common thing around the 100+ km's at this age, mine seems to be hesitating and getting worse in that way so ill have to do some testing sometime soon
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VZ acclaim wagon 04 3.6L
    Sep 2009
    I ham having similar probs with my 2004 model VZ. Auto Electrician is telling me its the ECU. Can you replace them with a used one from a wreckers or do you need to have them programmed for the car??
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    VZ's seem to have alot of electrical issues. dave1979m, perhaps it is the ECU, maybe it's just something shorting for a second here or there....
    Try a spark plug change ....... doesn't take long. If that doesn't work, have ur coils checked by an auto electrican. Both are alot cheaper then an ECU.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ SENATOR
    Mar 2009
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    BDC busting out the moves mate, thanks for posting some useful info as late!
    Life starts at 200km/h
    Sep 2009
    I have changed the plugs and have had the coils checked. The Auto elctrician said the next thing to check would be the computer mounted on the front of the the engine with the 2 plugs going into it. He has checked the wiring. I pulled it off and gave it to him to send and get tested but they can't test or repair these ones apparently. The car has been in the driveway for 5 days now. New from Holden these are $905. I can get a wrecked module but was wanting to know if you can just plug it in and away you go.
    Thanks for the replies.
  1. Odd vibration around 80km/h
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2009, 07:01 PM
  2. Engine Problems at 80km/h
    By kiddyl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2009, 12:06 AM
  3. brake shuddering, 100-80km braking
    By cds in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2009, 01:18 PM
  4. vibration between 80km/h - 85km/h
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2009, 08:43 PM
  5. Staffy + VY @ 80KM/PH = FRONT END GONE. VZ REPLACEMENT
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-06-2008, 02:04 PM
