Guys,
I keep getting the 'ESP Failure' when ever I am driving on the roads. This is starting to annoy me now!!
The driving style is normal, not in anyway enthusiastic!! (max. speed 50km/h). Whenever this warning comes up and alarms start beeping.. I pull over and turn the ignition off and the problem goes away. However, once started up and running at cruising speeds.. there goes the ESP Failure!!
Is it a problem with the ABS sensors.?? What could be the damage? Will I need to get new parts??
Thanks In Advance!
could be an abs failure. try getting someone to use tech-2 to see what the problem might be
Its a simple fiz my drive is a VZ Calais same issue recently Buy a new battery as the battery gets old it will upset sensors for a strange reason
could be worth replacing the fuse for the rear brake lights. i towed a trailer a little while ago and when i first started it up and put my foot on the brake, the fuse went and the ESP failed with it... replaced the fuse and it was all sweet
Posting in two threads? Same as other. Check battery.
i had this same issue after i hopped a gutter?
bent the lower adjustable control arm and then screwed with all the sensors.
