Results 1 to 10 of 10
Thread: cannot turn blinker off!
    svsex is offline big blue
    190 sv6
    Jun 2008
    Default cannot turn blinker off!
    i got a dtrange problem, when ever i lock my car or unlock it one of the blonkers will stay on and won't go off, even if i start the car and play with the indicators (the other one will blink but the other one will stay on). i have to unlock the car lock it agian like 5 times or so sometimes less sometimes more. its anoying as hell as u have to sit there like a retard trying to lock ur car haha.
    and it happens on a hot day, not in the mornings but in the arvos wen the car is in the sun.
    ive been told that the thionkgy that makes the blinker blink is work on contactor thing that works on heat or whatever,
    anyways it wud be great if sime one else has had this problem, might go see the holden dude at the parts store, or the auto sparky
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    its the BCM that's playing up. happened to me, got it replaced. can cost a mint. but PM or somehow get in touch with Dr.Rob on these forums to get it fixed. G luck.
    vx s pack II
    Jan 2010
    aLKIDA
    Sounds like the BCM mate. When replacing the BCM you will need to take it to Holden so that the security link can be reestablished. With the PCM/BCM/KEY. This style of VATS started from the VTs. (Were the PCM got involved)
    BCM are not cheap.
    You could get a second hand BCM that is the same level as the old one (LOW/MID/HIGH). To make life easier have the VIN number of the second hand BCM. and Holden will code you a new key for the BCM.
    Will be cheaper.
    190 sv6
    Jun 2008
    damn, thats a bummer, well il have to get on to this dr rob fella. anyways thatnks for the help, but another question, why does it happen wen its hot. really weird
    190 sv6
    Jun 2008
    VZ Executive
    Aug 2006
    Wellington, NZ
    Quote Originally Posted by PRAVX II S View Post
    BCM are not cheap.
    Will be cheaper.
    I would presume that it would just be a relay in the BCM that would need replacing (connectors being stuck). Replacing the whole bcm seems a bit of overkill if that is the case (not sure, but I'd expect it to be the case).
    190 sv6
    Jun 2008
    Quote Originally Posted by dolsen View Post
    thats what i was thinkin, might have to rip into the car tonight, any ideas where it is hahaha. might have to wing it and check all my connection that i think will effect the lights.
    thanks fellas
    vx s pack II
    Jan 2010
    aLKIDA
    I don’t think it’s a relay it will be some sort of transistor in the BCM that will turn on a external relay.
    VZ Executive
    Aug 2006
    Wellington, NZ
    Yeah, that's possible too. In a way, it's even easier to fix as it's easier to remove a transistor than a relay. If you know what pin on the connector goes to the indicator, trace it backwards and see what components are involved.
    Have a look at this thread, and possibly send pezouni a pm.
    190 sv6
    Jun 2008
    thanks, the bummer with new cars, everything is hidden, argh haha
    well i tried to check for earths and battery connectipons, but it stilll happened. only wen its warm. it always does it wen u least expect it
LinkBacks (?)
  1. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  2. Blinker Arm
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2007, 02:49 PM
  3. Blinker Help Please :-(
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2006, 12:00 PM
  4. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
