Results 1 to 6 of 6
Thread: Very Oily Manifold
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Very Oily Manifold
    Pulled my manifold off the other day to discover lots of dried oil in there.. I know the manifold circulates some oil out of the rocker covers, but was wondering how much is too much and if this may be caused by a faulty oil pressure sender, which mind youj has been replaced today.
    Also to eleviate this problem would an oil catch can help at all?
    Life starts at 200km/h
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    catch can will help , check your breaths and hoses for swelling and blockages too .
    VS V6 Acclaim
    Jul 2008
    Replace the PCV.
    Yes, a catch can will trap it before it reaches your manifold.
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Oil fumes get drawn into the inlet manifold from the crankcase via the crankcase ventilation (pcv) system when the engine is under deceleration, ie, when you take your foot off the accellerator , this is normal 4 stroke engine behaviour, these fumes condense into fluid which leaves oily deposit in the manifold. Unless your engine is using oil excessively (worn rings/valve stem seals) then it's normal to have oil film in the inlet manifold. Changing PCV valve wont help this normal event. Changing this valve is usually done when it sticks open & results in erratic idle &/or flat spots in acceleration.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    the pcv is also moulded into the rhs rocker cover...
    new cover is required... cant just change the pcv
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by colgf View Post
    thankyou !!
  1. Creamy/oily sludge build up on radiator cap
    By zx7rtas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 10:04 AM
  2. Replies: 5
    Last Post: 15-01-2009, 11:17 AM
  3. Oily leak from A/C compressor
    By thieled in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2008, 12:42 AM
  4. VS ute auto headlights fault / oily plugs help
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2007, 09:18 AM
  5. Oily intake pipe
    By dan-0 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-12-2006, 03:56 PM
