Results 1 to 10 of 10
Thread: VZ SS short shifter
    VZ SS
    Jul 2005
    Default VZ SS short shifter
    Hi there any body put a clubsport short shifter or any other short shifter into their SS or any one have a clue if that can be done and an approx idea of what it may cost ... will be great if some one has the info
    VZ 6.0L Club
    Aug 2005
    Default Short Shifter
    the HSV 'short shifter' is just the stick cut down. It does not change the shift length or mechanism at all.
    The throw is a little shorter, however the Harrop conversion or 'Digger' style conversion reduces the throw about 30 to 40% with a standard length stick. Otherwise there is the B&M or GM Motorsport replacements.
    If you want the HSV style short throw, you need to either shorten or your stick or buy one - plenty on eBay. Bolt off, bolt on. The others are more work.
    cheers
    VZ1
    vz storm ute
    Jul 2005
    Go to JHP Vehicle Enhancement site, they have short shifters. Once at home page choose, car ,ute ,or wagon it does'nt matter and then choose options.
    HSV COUPE 4
    Sep 2005
    Quote Originally Posted by vzss_01
    there are couple of options from www.############
    HSV style
    Harrop
    Rip shifter
    08 VE SSV M6
    Dec 2005
    Default SS short(er) shifter
    Just went and priced a Clubsport shortened gearstick from the local Holden, Believe it or not you have to buy the whole lot, stick, knob and boot for $576.
    Tell 'em they're dreamin' I say when just the shortened stick is $80 on ebay
    DA_VZ_UTE Guest
    Default Capa
    Try capa mate. they have afew different short shifters.
    www.capa.com.au
    PS. Did anyone else see the CAPA ute that ran into the croud last weekend!
    heat1 Guest
    Default VZ shifter seems good
    I owned 2 VYSS's ute sv8 and an auto sv8 at the same time yes $160,000 [ I did mods to them all]worth. they both seemed clunky but I now have a VZ and the shift seems as sweet as. When I bought it the saleman said that the whole upper shift mechanism was straight from HSV. I have read and it seams to me that the shifter is shorter than in the earlier models.If I thought I was going to do a paper on it I would of writen ndown were I got my reference material
    I never had any trouble shifting[ with the earlier sticks] I had more trouble when I put the wide rubber on the back and the clutch just spun. I will do some more research but the shifter feals like its almost an automatic to me. Dont like Sv8's? look at the 400m times
    08 VE SSV M6
    Dec 2005
    I recently bought a VZ SSZ ute (previously owned a VYII SS sedan) and I too looked at the price of a genuine HSV so called short shifter ( not actually a true short shifter but a shorter shifter, if that makes sense). I ended up buying one off ebay for $80. A high quality product with excellent fitting instructions. Basically remove centre console (top part only), remove gear stick suround, cut cable tie holding, leather surround off, remove gear knob, undo two bolts and off the old one comes. Simply the reverse to install the new one (lock washers are provided in the kit to use with the bolts - I used these and some blue loctite).
    I didn't want the shorter shifter for shifting reasons as such, just that I am going to mount a navman in the dash below the stock HU and wanted to remove the gear knob from blocking the screen.
    Cheers,
    Daniel
    Sensations Guest
    Mine cost for an original $200 got it off ebay- took me 5 mins to exchange.
    darren71 Guest
    I bought a Harrop short shifter through Corsa and are very happy with it.Dunno the price it was put on the bill at the end
  1. Short Shifter
    By nitchy69 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-07-2009, 01:03 PM
  2. VS Short Shifter Kit
    By pano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2007, 08:57 PM
  3. Short Shifter?
    By ElDubya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-10-2006, 11:02 PM
  4. Short Shifter kit?
    By To4e VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2005, 06:00 PM
