Results 1 to 17 of 17
Thread: VZ valve train timing chain issues
    2004 sv6
    Mar 2010
    Default VZ valve train timing chain issues
    just wondering how many people have had issues with the timing chains stretching or noisy valve train of some description
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    had a timing chain tensioner broken.. caused a tapping which increased with Revs. $1100 got it fixed and car back on road
    Life starts at 200km/h
    2004 sv6
    Mar 2010
    Just an update, pulled front off engine and so far have found idler gears on the timing chain have way too mutch play and lower timing chain has a bit of wear
    rough price from GMH is $1400 plus parts
    VZ executive
    Feb 2009
    warragul
    yer my cars doin it now got a mad rattle when cruseing at around 2-3k getting it fixed next week i think
    2004 sv6
    Mar 2010
    nearly there, assembled it this morning fired i up running like a clock.
    only thing now is I hace chek powertrain coming up with no trouble codes (next thing to fix lol)
    BTW I replaced nearly everything in the timing chain area approx $700 in parts alone (3 chains $280, 2 idler gears $160, gaskets $130, lower tensioner due to slight wear $60, plus coolant, oil, and gasket sealer)
    2004 sv6
    Mar 2010
    I think that's all of it now just re-seated some of the connectors I had disconnected and all is well now hopefully back to normal now
    great!!!! (didn't work still there)
    VZ
    Feb 2007
    seems like a big operation hope mine doesnt get that bad..any ideas to prevent it or will it just occur?
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    2004 sv6
    Mar 2010
    mine started around the 75000 mark
    I bought the car with around 19000 and had it regularly serviced since I had it and now for the hard bit of seeing if holden will do anything about since
    1. no one of their mechanics had noticed any sign of metal filings in the oil when it was serviced (about 18months out of warranty)
    2. I had reported it at 75000 service (the sservice department looking for the wrong noise)
    3. had it back there 2 months later (finally got someone to admit that they had never heard the noise only to say they think it may be timing chains)
    2004 sv6
    Mar 2010
    Well tht's all sorted now, went back over things and found I missed plugging in the map sensor on the inlet manifold at the back.
    LOL!! (one connector)
    Runs like a charm now no alarms either
    vz wagon
    Aug 2006
    Wild west of Melb
    Was it a hard job to do ? I been told ya need a tool to lock the cams to stop them turnin on ya as mine needs a chain now ? done 110 thou and done a water pump at 98 and all the bushes and struts in the front end have been replaced not real happy with the vz wishin I got a vy now.
    2004 sv6
    Mar 2010
    When you are told the timing chains are stretched it may not b the case as with mine I was told it MAY be timing chain noise. however when I pulled it down the chains appeared fine and it was worn idler or intermediate gears on the timing chains. this may be why they say to replace them as a set (to cover the fact that there may be some sort of flaw with the setup).
    I wnder how many peopl have been told it is chains whe it i actually the intermediate gear?
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    I've got a feeling mines about to go. It's down on power and pretty noisy at idle. Might see if I can tackle it myself.
    2/06 VZ Executive
    Apr 2012
    Hobart
    I must be one of the lucky one's (until now), i have an 06 Executive (Taxi) that has clocked up 340,000ks. Replaced Two water pumps, two radiators, numerous oil pressure sensors which all seems standard in these models. Lately she's rattling very loudly at idle but seems to settle down some under a bit of a load. Mechanics cant or wont find/commit themselves to finding the problam without the expensive process of elimination. Anyone have more experiance/information than these jokers?
  15. #15
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by 2004_sv6 View Post
    I think you will find its the stretched chains that are wearing the gears down as they no longer line up properly when they are stretched.
  16. #16
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Cab669 View Post
    Id say its the timing chain on its way at first they only do it at idel and as ya pick the revs up it will pull the chain a bit tighter and wont rattle but after a wile the rattle will stay the only ather thing to check is if the harmonic balancer is on tight as the one on mine was not tight and after a wile it lets the bottom gear float in and out and that rattles on the timing cover aswell.
  17. #17
    2/06 VZ Executive
    Apr 2012
    Hobart
    Quote Originally Posted by Clutchy View Post
    Cheers mate, appreciate any help. Loosing faith in Mechanics and Holden Dealers, best advice seems to come from those who actually drive these cars every day,
  1. valve train geometry
    By esaad in forum V8 Development and Modification
    Last Post: 09-09-2009, 05:52 PM
  2. Buick valve springs, valve train. need advice
    By GTP 85 in forum V6 Development And Modification
    Last Post: 25-08-2009, 10:22 PM
  3. What oil for ls1 with noisey valve train
    By Ripcell in forum General
    Last Post: 05-08-2009, 11:10 PM
  4. VN v6 valve train
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2009, 02:12 PM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
