Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: VZ Overheating Mystery
    VZ Executive
    Mar 2010
    Default VZ Overheating Mystery
    Hopefully someone will be able to guide me to work out what has failed.
    I have already had the radiator cleaned, had the cooling system pressure tested, and I have replaced the cap twice as I know the caps are unreliable. Also the fans seem to cut in appropriately. There are no leaks apparent. The exhaust does not appear to blow steam, and there does not appear to be any coolant in the oil, or vice versa. There is no strange residue around the oil filler cap.
    What normally happens is that the car temperature gauge stays around the 25% mark for approximately half an hour of driving and then will shoot up rapidly to 100% and the overheat alarm sounds. It doesn't need to be a hot day for this to happen.
    On a cool to cold morning the temperature stays just below the 25% mark. On these occasions there is no drop in coolant and the overflow reservoir stays at the same level.
    On days where it hasn't overheated, but the temperature has drifted a little above the 25% mark, I have found that more coolant has been pushed out into the overflow reservoir than what is sucked back, but it isn't a huge amount. All checks of the overflow reservoir have been done after the car had completely cooled down.
    On a couple of occasions I have had the temperature operate at the 25% mark, shoot up wildly to around 75%+, shoot back down to normal, shoot back up again, then down and stay down until I got home. On another occasion it continued to shoot up and down for the whole journey (but on all of these occasions it was about 30 minutes before the strange behaviour started).
    I have removed the radiator cap and watched the water circulating as the car gradually heated up. The first thing I observed is that bubbles appeared every so often as the water circulated. If I slightly pressed the accelerator the water will overflow. Every so often the bubbles became extreme to the point of the water foaming, and then return to bubbling every so often. The water level also fluctuated up and down. After approximately 30 minutes (and rapidly without any real warning) the water appeared to boil with steam and water spurting out. A check of the temperature gauge indicated that it was still only a little above the 25% mark.
    So what I have concluded is that with this problem, the gauge may be still be at around the 25% mark with the system being hot enough to push coolant out of the overflow. I'm assuming once enough coolant is pushed out that the temperature will start fluctuating or rapidly hitting the 100% mark.
    Any pointers to what could be the problem would be greatly appreciated. I am down to the water pump, thermostat, or head gasket. None of these are things that you want to fork out to fix without some hope of being right.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    well i would be changing the thermostat as they arnt hard to change at all. i think most commodores have a 95* thermostat from factory most people change them to a lower temp one like 81 or lower, it allows the cooler syster to start quicker and start cooling down the motor better.
    Have you checked all the hoses are fine? there might be to much air in the water?
    maybe the water pump needs replacing? have you taken it to holden maybe the tech 2 scan tool will tell you the problem!
    im only putting sugguestions out there for ya.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VZ Evec 05
    Jan 2010
    South Coast NSW
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    really opps my bad. id still say change it tho
    VZ Executive
    Mar 2010
    Does anything I wrote, positively remove either the water pump, thermostat, or head gasket as a possible cause? Can I discount any of these three?
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    replace your thermostat. That is all it could be going by the symptoms you have described. I had the same symptoms in my old sigma... The thermostat worked, but it was "stick". I reckon you have the same prob. Get it replaced!
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Yep thermostat. To bad it is in a bitch of a spot and some mech's even drop the box to get to it lol.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    It may well be the thermo sticking and then releasing sporadically but before I did a change I would be doing another coolant flush and refill and then test it out. This time it's done make sure the system is properly bled of air because from what you have said you may have a hell of a lot of air in your system.
    You said:
    "I have removed the radiator cap and watched the water circulating as the car gradually heated up. The first thing I observed is that bubbles appeared every so often as the water circulated. If I slightly pressed the accelerator the water will overflow. Every so often the bubbles became extreme to the point of the water foaming, and then return to bubbling every so often. The water level also fluctuated up and down. After approximately 30 minutes (and rapidly without any real warning) the water appeared to boil with steam and water spurting out. A check of the temperature gauge indicated that it was still only a little above the 25% mark."
    I assume the bubbles you refer to are air bubbles. If you do have air in your system you will potentially get blockages in coolant passages and you will get an overheating problem.
    Before I rushed off to replace the thermo or anything else I would first test to ensure your problem is not caused by inadequate bleeding of air from your cooling system.
    I would query who did the last coolant flush and change in the car and whether they used the correct procedure to ensure all air is bled from the system after the refill. Bleeding out the air is critical to achieve unblocked coolant circulation and correct operating temp.
    Once you have eliminated air locks in the cooling system as the cause of the problem go on to the thermo. If this was my car this is what I would be doing given that a thermo change is a hell of an exercise in your motor. Just make sure you use the correct GMH spec coolant for your vehicles cooling system (refer owners manual) when refilling the system.
    You also mentioned that the problems with the temp changes does not occur until after 30 minutes of operation.
    "On a couple of occasions I have had the temperature operate at the 25% mark, shoot up wildly to around 75%+, shoot back down to normal, shoot back up again, then down and stay down until I got home. On another occasion it continued to shoot up and down for the whole journey (but on all of these occasions it was about 30 minutes before the strange behaviour started)".
    With a faulty/sticking thermo I would expect problems to show themselves much sooner than after 30 minutes of engine operation each time.
    Anyhow best of luck with it.
    VZ Executive
    Mar 2010
    Sean880...
    Yes I agree it doesn't make a lot of sense. I had forgotten to say that I had the air bled from the system, but unfortunately it wasn't done by a Holden mechanic. This also doesn't explain why it started in the first place. Also the air bubbles just keep coming. I have watched for 45minutes and the rate of bubbling fluctuates as described, but they do not stop. Also the water level does not go down as the bubble are released. I was worried that the bubbles indicated a head gasket problem, but I was told that these systems can create their own bubbles (Would someone like to check theirs to confirm this?).
    Another thing that made me think head gasket was that it kept pushing extra coolant out of the overflow. Not much extra comes out (unless it goes really hot), however it will continually loose more coolant than it sucks back in (unless it is a quite cool day).
    Something else I forgot to say is that it started overheating only on really hot days after about 1.5hrs of driving. It has been gradually getting worse for the past 2 months to the point that it is only taking about 30 minutes and it only has to be a warm day.
    In my head I keep flip flopping between head gasket or thermostat.
    Could it be the thermostat sticking so that the engine runs hot enough to push a little bit of coolant out the overflow, and I don't have big problems until a certain amount of coolant is released? The problem with this idea is that the temperature gauge only shows a little above 25% for the extra coolant to be released, and I suspect that not much would have been released in the 30 minutes it takes for the temperature to start going too high.
    You can see why I am scratching my head. Most people appear to be saying thermostat. I have to take a punt soon, as I don't have any confidence on what is the route cause.
    Last edited by Aussie_Dark; 08-03-2010 at 07:56 AM. Reason: added more information
    May 2009
    VIC / NSW
    I would also have some tests run to see if you have engine gasses blowing into your cooling system via the head gasket.
    Don't delay having it looked at by a competent mechanic as you don't want to cook your engine. The good ones will do a proper diagnosis before they recommend solutions. The alsorans will guess and want to start replacing this and that in the hope they stumble on the solution.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Make sure there's no blockages in your exhaust etc.... cats etc. I had my temps going up and down wildly at one stage, was a blocked resonator on one side....
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Black VZ SV6
    Dec 2005
    Blocked resonator? .. WTF. Talk about throwing him right off course!
    Aussie Dark: it will be either your water pump (classic symptoms) or thermostat.
    I would most likely be inclined to say water pump, as I have had mine replaced
    with the same symptoms - and fixed all problems instantly.
    Drive it
    Like ya stole it!
    Sep 2008
    tru that...... happened to me tho. but yeh, waterpump most likely then thermostat.
  15. #15
    VZ Executive
    Mar 2010
    Wow... water pump. What issues did people have with the water pump? It would be great if it was the water pump as I think that this would be the easiest thing to replace.
  16. #16
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    simple answer is they leak, and leak big time!!!
    But VZ's are known for having both issues, thermostat and waterpump
  17. #17
    VZ Calais
    Jul 2009
    my WP was leaking and has been replaced, although i'm 100% sure it's working properly as the temp still goes above that 25% mark more often than it used to...
  18. #18
    VZ Executive
    Mar 2010
    My water pump is not leaking... does that point me back to the thermostat?
  19. #19
    vt ecotec
    Mar 2010
    brisbane
    too know if thermostat
    drain coolant (bung under radiator)
    fill and (in vz only vt is on thero housing under eng cover)
    bleed BEFORE starting at bleedr top right hand side of radiator,
    then hold revs at two thousand until fans come on this is SUPPOSED to be when the thermostat opens (this takes five ten minutes)
    when fans come on level in fill port (where cap is) should drop significantly,
    fill and when fans turn off bleed via screw rh top of radiator again.
    if level doesnt drop or fans dont come on WHEN fans work when driving only! then thermostat is shagged,
    will not set any codes and most holden dalers sadly will miss this point. if not bled as above eventually will destroy thermostat anyway!!!! very "common"
    also dont mix coolant colours fork out the cash and get genuine coolant can make a 10-40 degree difference in temp reading!!!
    by the way qhwen doing above blleed procedure have the overflow tank hose (where you can top it up yellow cap) pushed into where radiator cap was or block it off.
    hope this helps if not msg me!~
    by the way thermostats also have THREE o-rings on them in vz/ve that must also be replaced at the same time!2 for heater lines and one for lower radiator hose connection
    also if not bled properly will resemble a blown headgasket ONLY vz/ve i have had head blown on is lpg taxis/limos at around 250,000km's with wrong coolant so take the hint!@~
    Last edited by sssmechanicholdenbrisb; 11-03-2010 at 09:38 PM. Reason: missed info
  20. #20
    VZ Executive
    Mar 2010
    Thanks SSSMechanicHoldenBrisb.
    Sounds like I have something to do this weekend.
    I can confirm that the fans do not come on unless I drive the car, however the cooling system would not have been bled as you indicated. The level does drop, but then fluctuates up and down a lot.
    I'm going to cross my fingers that this positively identifies the thermostat as the problem. Will post on the weekend after I do the test.
  21. #21
    vt ecotec
    Mar 2010
    brisbane
    yes in the five ten minute period will "fluctuate slightly" level rise drop sometimes a lot ! this is due to the expansion of the coolant and air locks being forced out
    so to recap more simply
    drain
    fill
    bleed
    start
    2000rpm till fans on
    off
    bleed
    cap on while off
    top up overflow
    notes:
    always top up if level drops MUST BE FULL THE WHOLE TIME if not full to cap top! as else will let air in
    keep overflow hose into fill cap or block off
    to bleed: engine stopped fill up open screw (a bit! not take off completely) located @ rhf top radiator vz
    and keep topping up until only fluid comes out the screw close screw
    Also during whole procedure:
    set heater too hottest
    fan speed two
    on the windscreen only (top of dash only)
    A/C OFF or fans always on
    that is from the manuals guys all accesibbale info through haynes etc etc.
  22. #22
    VZ Executive
    Mar 2010
    Thanks again SSSMechanicHoldenBrisb...
    Just another question. What does the bleed screw look like? Is it the black plug facing the back of the car at the top right hand side of the radiator as you face the front of the car?
  23. #23
    vt ecotec
    Mar 2010
    brisbane
    hey mate sorry long day today did 23 cars im F**ed
    the screw isa a Phillips head (unless aftermarket radiator) and yes is at top rh side facing the engine side very easy to get to just remove the cover's six or so clips and take cover off!!!! good luck and let us know how you go!~
  24. #24
    VZ Executive
    Mar 2010
    23 cars... that's amazing.
    OK... I did what you suggested and I am pretty sure I did not get the expected results.
    Observations:
    1. A small amount of steam started to occur fairly quickly after starting the car (about 1 min).
    2. As the time progressed the bubbling became more and more violent and coolant was spewing out of the fill port.
    3. Ran the car for 11 minutes. Coolant continued to spew out of the fill port and the level never really dropped.
    4. After 11 minutes I stopped the car and the coolant dissappeared from the fill port. I topped up the level and it took at least 2 litres.
    5. The fans did not come on at any time.
    6. The maximum reading on the temperature gauge throughout was just above 25%.
    After pleading with a service manager of one of the larger dealerships in Adelaide, I am dropping the car off for special attention. It is sad that the previous two times resulted in a changed cap, then a tightening of a clamp, instead of doing a complete investigation on it like I had hoped, but I feel more confident now that it will get the attention that it needs. I'm thinking that based on your advice that we have positively identified the problem as the thermostat.
    I'm going to get to talk to the mechanic direct, so if I tell them what I have done then do you think they will be equally convinced?
    Thank you very much for taking the trouble for helping me. I will post the outcome after Monday.
    (Now comes the challenge of driving it to the dealership, which is over an hour away.)
  25. #25
    vt ecotec
    Mar 2010
    brisbane
    hey mate sorry to hear that happen!
    the ":boiling" of coolant as you describe is normally caused by a completely sieazed closed theremostat and so instead of criculating the coolant from the lower radiator hose it just boils the coolant inside the engine so as the sensor for the fans never senses the thermostat open it just reads the HOT AIR around the sensor which is not high enough to signal the fans on
    will need (likely) thermostat ALL new coolantand a bleed
    when you get your cart back dont open the cap unless you have a problem with overheating still as norm,all they will bleed the sytem very well especially if you have spoken to the service manager, trust me if he is involved it will come back fixed!!!!!~~~
LinkBacks (?)
  1. my little mystery...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2008, 05:20 PM
  2. mystery miss, please help me!
    By morgspothead in forum General Discussion
    Last Post: 02-07-2008, 02:19 PM
  3. Electrcal Mystery
    By PorterVs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2008, 02:35 PM
  4. Mystery Noise
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2007, 01:47 PM
  5. Mystery box
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2007, 09:18 PM
Tags for this Thread
