Results 1 to 19 of 19
Thread: VZ SV6 foglights idea
    VZ SV6 SA5
    Feb 2009
    Renmark SA
    Default VZ SV6 foglights idea
    Hi guys, not too long ago i got done for driving with my foglights on and got a $170 odd fine *ouch* anywho i like driving with the most light possible and was wondering if anyone knew how to set up the foglights as spotlights so that they come on when i turn my high beams on?
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Well, you should'nt drive with your high beams on in an urban environment anyway. Thats what the street lights are for. You don't need fog lights in the city, just asking for trouble.
    Can't you pull the light switch out to turn the fog lights on? Mine does'nt have them.
    chevZ's Avatar
    chevZ is offline bringin' rocko spec back
    [L3GALLMT]
    Aug 2008
    WHERE DA PEEL OUTS AT?
    Quote Originally Posted by VzVzVz View Post
    He was driving with FOG LIGHTS on not high beams, he had an idea though to set it up so whenever you high beam your fog lights come on, which is a great idea that they should do already if you ask me.. but holden didn't see that necessary..
    He's just trying to save the step of high beam + pulling out the fog light switch, making it a bit easier and practical.. it can be done mate just take it to any auto elec place that deals with stereo systems and all that sort of gadgets, over here we have a place called Kirkys Kustoms that does that.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by CoJang View Post
    It would be pointless doing this, as you would have to adjust the foglight aim. As the light is aimed down not up.
    Just buy a set of Narva or Hella driving lights.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by PaulSV6 View Post
    He'd still get done if he fitted the driving lamps because they're not factory fitted.
    but in saying that holden market the ones you already have as driving lamps
    as paulsv6 said, there is no point in having the ones you've got come on with high beam because if you hit fog and switch them on you'll blind yourself.
    Chev badges are an instant fail
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by ashbox View Post
    Well that's definitely wrong.
    Lets not forget, there are differences between fog & driving lights! They serve two totally different purposes.
    The Blue One
    Quoted for truth
    MY10 VE SV6
    Sep 2004
    Blue Mountains, NSW
    When I had the VZ I did just that - wired in a relay under the bonnet so that when the driving lights came on the fog lights came on too. A change of bulb in the fog lights gave good light in a wide spread. It made them useless as fog lights, but I never thought they were real good for that anyway, and we get a LOT of fog in winter here.
    Worked for me, but thats also country driving, not city stuff, and on my trip to work it's not unusual to see roo's, wombats and a lot of rabbits and foxes, so while the high beam was good at a distance, it did leave a bit of a darker patch closer to the car and off to the sides,. This mod fixed it, at least for me, but I did remove the relay & drop the original globes back in before I sold the car.
    Ride: MY10 VE SV6, Poison Ivy, White LED Footwell and boot lighting, JBL GTO608C front speakers, JBL 6*9 rears, JBL 4 chan amp and low level outs in the head unit
    Custom Plates
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    just checked the holden website and i stand corrected, holden have change their marketing
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    yeh theres often confusion about "driving lights" and "fog lights"
    the fog lights on the VZ are fairly useless anyway, cop any decent fog like through mountains, and their pointless. Go back to the VX, thats when you find a semi decent fog light.
    VZ SV6 SA5
    Feb 2009
    Renmark SA
    cheers guys. like everyone has said yes this is for highway/out of town driving. MySv6 you couldnt tell me how to install a relay like you did if you remember could you? and also what bulbs you put it?
    MY10 VE SV6
    Sep 2004
    Blue Mountains, NSW
    Bulbs - 100W, but it was done when the bumper came off, and I made an off-handed comment to the mechanic - how about we throw 100 Watt globes in there, so he did lol
    The setup actually used 2 relays - I found the fog light wire and cut it, adding the light side of the wire to one side of a relay. The other side went to 12V via a 25A fuse. The wire from the car went to the coil & the other side of the coil to earth. That way turning on the fog lights activated the relay and drew power from an alternative source via the 25A fuse to the globes.
    The second relay had the same 25A fuse supplying one side of the contact, and the other side went to the same light wire. One side of the coil was earthed, and the other was joined to the wire connected to one of the driving light or high beam wires, so activating the high beams activated relay 2, making the fog lights operate.
    The reason I did it this way was only that I was not sure is the original wiring loom & setup for the fog lights was designed for 15+ amps which the 2*100W globes drew, so the relay seemed a safer option. Also operating the original fog light switch OR high beam caused 1 of the 2 relays to operate & turn on the lights. Because I used a base for each relay, the high beam one could be unplugged, rendering it not working & returning the car to stock operation.
    Oh and if you look about relays are cheap & you might be lucky and be able to fit the additional relays in the relay/fuse box under the bonnet too
    Custom Plates
    VZ SV6
    Sep 2009
    Wingham, Mid North Coast, NSW
    $170 thats a joke, i got pulled over for them, thank god they didnt fine god knows wat i woulda sed
    but they are useless in fog but make driving so much easier of a night
    When in the chicken coup, if i wanna get lucky, i get clucky clucky
    VS SS V8 Ute
    Nov 2009
    WA
    can u have your fog lights on at night? i reckon they look sik turned on even when its day
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    With the introduction of the Australian Road Rules, I'm sure it is pretty consistent across all State/Territories.
    In short ............. "Fog lights may only be used in situations with limited vision (fog, rain, smoke). You must turn fog lights off once conditions improve."
    Source - NSW RTA Learner Driver Log Book (my son's old book was laying around).
  15. #15
    2005 VZ Commodore SV6
    Mar 2010
    Just wondering, how do the foglights on the vz sv6 work? Do they come on automatically or is there a way of turning them off/on?
  16. #16
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    the light switch pulls out, which turns the foggies on
    Spoken by a true member of The Committee
  17. #17
    Torquative's Avatar
    Jun 2005
    the headlight switch pops out to have them on and back in to turn them on.
    just grab it and pull it out!
  18. #18
    Mar 2010
  19. #19
    VZ Berlina
    Jul 2010
    haha i wondered the same thing for days when i got the berlina.. glad i wasnt the only 1 lol
  1. [VIC] VP SS Foglights
    By VQ-Assault in forum Parts And Other Items For Sale
    Last Post: 22-08-2009, 01:19 PM
  2. [VIC] Wtb vn ss foglights
    By SthEastCustoms in forum Swap / Wanted to Buy / Trade
    Last Post: 21-08-2009, 10:18 PM
  3. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  4. VX foglights on VT
    By corkabro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2008, 06:09 AM
  5. Foglights into SSX bar
    By Jesterarts in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-10-2007, 08:32 PM
