Results 1 to 3 of 3
Thread: SRS Air bag fault - HELP PLEASE !!
    vz sv6
    Nov 2009
    Default SRS Air bag fault - HELP PLEASE !!
    my air bag light cam eon after i put in a stereo and ahad a flat batery, i have tried all the computer reset thoings like taking the battery off ofr an hour etc. i ttok it and got it scanned and their was no error code, and they couldnt reset it or fix the problem, so it still comes up. What could be wrong how do i fix it?
    HELP PLEASE
    VZ Exec Wagon
    Jan 2010
    Try and isolate what you did..
    Is your stereo:
    Hardwired/Cut loom - I'd return the car to 'factory'.. undo everything you did & put the old stereo back. Then you might be able to eliminate any wiring fault..take it back and get it re-tested.
    Adapter harness - should've been ok, no suggestion apart from pull it out and put the factory things back and try reset / retest it?
    Did you short anything? Leave something unplugged? Double check everything's plugged in..
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    did you take your airbag off the steering wheel?? if you dont put the wiring plug back on the airbag the right way around it will log a warning light & has to be reset by using Tech 2 tool (dealer visit)..
  1. abs fault?
    By Escape-The-Fate in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2009, 02:54 PM
  2. A fault already??
    By KITTAU in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-05-2007, 03:45 PM
  3. Is this VP fault, V6 fault or just bad luck?
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2006, 10:46 PM
  4. fault 31
    By mark1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 07:32 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
