+ Reply to Thread
Results 1 to 24 of 24
Thread: more acceleration on my vz
    ve calais international 6.0lt
    Mar 2010
    Default more acceleration on my vz
    i drive a VZ MY06 berlina and i dont really have much of a clue on cars but i wanna be able to beat my mates off the line. Any tips would be helpful
    cheers
    TVR-190's Avatar
    TVR-190 is offline Temporarily Unbanned TVR-190 Senator TVR-190 Senator TVR-190 Senator
    WK Statesman V8
    Jun 2008
    Cronulla, Sydney - Australia
    tune / diff gears
    TVR-190: That LSD service paid off. Stato just got very sideways.
    Grennan: In a stato, the term is held starboard.
    Mar 2010
    do cold air intakes, performance chips do much
    and what can i do to the diff gears? costly?
    ashbox's Avatar
    ashbox is offline 6 speed ashbox Executive
    something silver soon
    Apr 2007
    The Car
    diff gears around 1200
    tune around 1000
    have a look at the sticky threads at the top of the vz section, it will list everything you need to know
    Chev badges are an instant fail
    vt ecotec
    Mar 2010
    brisbane
    I recomend extractors and wider wheels most of my customers stop there. but if want more can change diff /final drive ratio, strut tower bar also cheap and very effective in vz due to welds on a pillar are AWESOME if you have ever seen gaurds off slotted front rotors is next then usually springs, after this you have to choose how much and how far?
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese... CANYONERO Calais
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    TVR-190's Avatar
    WK Statesman V8
    Jun 2008
    Quote Originally Posted by sssmechanicholdenbrisb View Post
    how do slotted rotors help with acceleration.
    OT: Stage 2 Shift kit should help.
    wraith is offline Banned wraith Berlina
    '96 VS Exec
    Sep 2008
    Neverland
    Quote Originally Posted by TVR-161 View Post
    Slotted rotors? Light weight? Shift kit will pick it up a bit.
    2006 VZ SV6
    Nov 2009
    You need to let us know your budget. Also might help to know what your friends are driving so we know how far your car needs to go to beat them.
    There are cheap mods that make small amounts of difference, then there are big expensive mods like superchargers and whatnot. All depends on what you want to spend.
    TVR-190's Avatar
    WK Statesman V8
    Jun 2008
    take out your spare tyre and any excess weight.
    '96 VS Exec
    Sep 2008
    Neverland
    Unless OP is in QLD where it is a defect not to carry a spare and jack.
    Mar 2010
    Well they drive wagons mostly. Vy series 2 vt and vz. I have a year left until I am 21 so I wanna buy a v8 but in the mean time beat my mates. The car I drive can be sold as a
    luxury car so I don't wanna mess around to much. Preferably do stuff that I can take out or change back. I don't care to much about the cash as long as it's not a dumb amount of money haha.
    Exhuast on a 6 I think is dumb because sounds crap and will never sound like an 8 so I would rather steer clear of that.
    1 of my mates was saying u can get hsv chips or after market hips that change your fuel intake and that???
    And I will look into some of those other ideas. Thanks heaps
    Torquative's Avatar
    Torquative is offline go in Luxury Torquative Caprice
    5.7 Barge and Cross 6 Adventra
    Jun 2005
    havent been able to chip a car for years
    Troy, yeh stage 2 shift kit .... umm if it works. Cost me a new gearbox in mine, expensive lesson there
    Mar 2010
  15. #15
    ashbox's Avatar
    Apr 2007
    The Car
    they no longer use chips, they plug a machine into the car and bingo, prob a bit more involved than that but yeah, they dont use chips
  16. #16
    Berlina
    Oct 2009
    Quote Originally Posted by Torquative View Post
    What happened mate?
  17. #17
    vt ecotec
    Mar 2010
    brisbane
    response: most of my customers go for slotted front rotors cause their sick of maching and replacing for BRAKE SHUDDER common in these models especially in higher power situations which means heavier braking causing excessive heat disperition in rotors mainly in fronts due to R.W.D. being 60:40 brake distributionas for removing excess weight will only make a difference if already at VERY high end power numbers as at low end is like fust advancing timing VERY MINIMUL gains but if you want a fifth of a second YES, and yes in queensland you can be defected for no spare tyre but only if you didnt throw it out yesterday cause of a flat... that you'll get fixed tomorow
    Last edited by sssmechanicholdenbrisb; 11-03-2010 at 09:54 PM. Reason: explained cause of brake shudder by adding power
  18. #18
    TVR-190's Avatar
    WK Statesman V8
    Jun 2008
    Dont be so quick to throw out the weight loss, My VP was half a second quicker to 100 minus spare wheel and some tools in the boot. And its not exactly a high power vehicle.
    Hell id be alot quicker runner if i lost 50kg of weight
  19. #19
    vt ecotec
    Mar 2010
    brisbane
    true but it depends how much you want to spend to gain weight loss is always going to make a difference but it depends how much you want to CUT out, e.g. fuels is almost 1kg per litre if you only put in enough to do your run this is a large weight saving remedy
  20. #20
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    I dunno. I have diff, tune, headers, insulators etc etc.........
    Probably I'd go diff n tune make the most difference. But mostly a good tune will definately get you off the line faster then most..... but it does require a bit of tweaking. Personally I'd love to learn some weight reduction tips.... other then removing the spare wheel etc.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
  21. #21
    VZ Acclaim Wagon
    Oct 2005
    If they no longer "Chip" them, how or who can plug it in and improve performance..?...Holden dealers..?.. in Vic..?
  22. #22
    carless for now
    Feb 2007
    perth,Western Australia
  23. #23
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Diff gears and a VCM tune will be more then enough. I actually want to get diff gears for my SV6, how much do they usually cost?
  24. #24
    svsex is offline big blue svsex Executive
    190 sv6
    Jun 2008
    Quote Originally Posted by bigdaddycool View Post
    haha rip everything out haha
+ Reply to Thread
  1. most acceleration on my vz
    By jjaassee in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-03-2010, 09:02 PM
  2. VN has no acceleration
    By snowbeast in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2010, 05:51 PM
  3. Help! need help with acceleration!
    By fatboy15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2008, 10:18 AM
  4. Acceleration on VT
    By HamaTime™ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2008, 09:43 PM
  5. bad acceleration
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2005, 03:23 PM
