i was wondering if it was possable if i could use a ve flip key on my vz commodore?
doubt it. havent looked at the VE key but i doubt it has the metal knob on the outer side of key. this goes in contact with a ring on the ignition to send the security code i think.
may have to make a phone call in the next couple of weeks then
Chev badges are an instant fail
Whats the actual flip key look like? do they look like the VE keys?
I might have to check this one out too. I absolutely hate the clunky big standard key - takes up half your pocket and it's awkward to handle when your hands are full with shopping etc.
would the flip key be backwards compatible with the vy key? Id be keen on it too, if thats the case. Cant stand the bulky key.
as said before, the vy key uses a contact point to send the code across to disarm the immobilizer were as the ve uses a transponder chip witch transmits its code as a radio frequency, they are not cross compatible, correct me if im wrong but i have never seen a vy with a flip key an i cut about 10 commodore keys a week at work..
Signature Goes Here
Yes, I understand that the VE key isn't suitable but Torana355 said that VZ's could get a flip key - that's what I intend to chase up, to find out if it's compatible with the VY.
will check it out at work today, il check the catalog out an see if i can get anything like it..
Signature Goes Here
Hey guys even though the bloke at Holden said i could get a Flipkey i didn't actually get one as they were to expensive. He may have been wrong though.....
how much were they?
Just called Holden Parts, they reckon there's no such thing as a flip key for a VZ. Can you by any chance get a part number if one does in fact exist?
"Nonsense, this is the kind of coverings what we humans wear at this period of time. I'm quite sure of it."
See my ride here
I had a feeling something didn't sound right.....
A guy on the LS1 forums bought a VE flip key and tried to make one himself. He put a lot of time and effort into it but unfortunately couldn't get any results.
