Results 1 to 10 of 10
Thread: VZ intake idea
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Default VZ intake idea
    Hi all,
    So I have been mulling over improving the intake on my VZ wagon. It is currently fitted with an SS front bar, with the standard fog light arrangement.
    Just wondering if anyone has seen/tried using the two holes in the bar as intake ports? Even if you haven't, what do you see as the pros/cons?
    Cheers.
    New to the VZ bandWAGON...
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    good idea BUT the first issue is during rain your going to potentially suck water into the airbox ...
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    True that. That was one thing playing on my mind... any suggestions for guarding against it?
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    mines prob a a bit different but i got 2 big intakes in the lower cut out of section on a vt bumper and never had an issue with and water in 2 years, and been thru few decent puddles.
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Did you notice any difference in economy/performance with the mod?
    Sep 2009
    goldcoast
    Quote Originally Posted by zvagon View Post
    yeah, there was a fair bit of difference in performance, where 100% happy with it, definatly worth the $35 or whatever it cost,
    have to put a few pic's up soon cause a few people asking how i did it.
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    If you want to improve performance just change your air filter element every 12 months or every 6 months if you do a high mileage and clean out the filter box.
    These filters are cheap to replace and make a big difference. It is amazing how clogged these can become in a fairly short time.
    Drawing input air that low to the road will result in more dust and debris being picked up so you will need a primary mesh guard rigged up to keep out the larger material like leaf litter, paper and the like.
    Sep 2009
    goldcoast
    i havent picked up 1 leaf in 2-3years. and doubt theres any more dust 40cm off the road compared to 80cm of the road. and havent picked up a drop of water either.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    correct me if i'm wrong but this would also cause the air to take longer to get to the actual engine....... i've tried a number of setups, the longer the run the more torque u seem to get but it does delay power a tad.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ Wagon 9C1
    Feb 2010
    Dora Creek, NSW
    Hadn't considered that conundrum, but it makes sense I guess. Thanks for the heads up!
    Anyone else with experience/opinions?
    Seems like the two-hole MCAI might be the best bet.
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  3. SV6 Custom intake idea
    By nikolas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-11-2008, 08:39 PM
  4. 1st Car....what you think (idea)
    By Frandy in forum General
    Last Post: 23-03-2007, 09:39 AM
  5. My Sub Box Idea
    By TigerVX in forum Car Audio
    Last Post: 14-06-2006, 01:07 AM
