+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 63
Thread: VZ mobile phone car kit
  1. #26
    Thecrewmanbloke Guest
    Quote Originally Posted by Y2kGoofball
    crewmanbloke, was it hard to do? did it take long?
    I tried to pull the console facia out on the weekend to have a bit of a look but couldnt get it free for some reason.
    Not long at all, I think it took about 2 hours.
    I just followed the instructions from the link below and ordered the parts from Holden.
    You will only need one switch for a Nokia car kit.
    The cost of the car kit and parts from Holden was :
    Nokia CK-1W car kit on EBay $80.00
    Parts from Holden ( 1 x phone switch and cover $35.00.)
    Total $115.00
    A lot cheaper that $450.00 quoted from Holden for a genuine Bluetooth car kit.
    Let me know if you want the parts numbers.
    And here is that link on how to pull the centre console apart and install the switch.
    http://members.cox.net/05gto/html/bo...on_install.htm
    ___________________
    thecrewmanbloke
  2. #27
    fourstar82's Avatar
    fourstar82 is offline Graphic Designer fourstar82 Executive
    VYII 25th Anniversary
    Jan 2004
    Templestowe, Melbourne
  3. #28
    Road_Pilot is offline Road_Pilot Road_Pilot Executive
    VZ Executive Wagon
    Aug 2005
    Hi Sammy,
    Yes it may look busy but very functional, The switches are for the various warning lights fitted i.e. 2x rotating beacons, front "Wig-Wags", front grill flashers, roof mounted front facing light bar with 3 selectable light patterns, and rear facing small light bar.
    The radio is the split system with the operating head mounted in front of the window switches.
    The main phone is on the left with the cdma on the right.
    All in all it works well.
    Jim
  4. #29
    Nov 2005
    Hi Thecrewmanbloke,
    I am wanting to connect my Nokia car kit in my VY using the same phone button and surround. Could you give me the part numbers of the button and the new surround trim? I also plan to use the bulb that comes with the switch rather than replacing it with a LED. It will mean a little more wiring and a few electronic components but I want it to look the part at night.
    Thanks
  5. #30
    Quote Originally Posted by assa73
    Hi Thecrewmanbloke,
    Thanks
    Here are the part numbers that you asked for:
    GM-92172331 - Phone switch - @ $26.44
    GM-92165670 - Bezel one hole - @ $7.46
    The light bulb that comes in the switch is 12v. I changed it with a 3.4v super bright green led and it looks the same as the power windows switches at night.
    Enjoy the installation let me know if you need anything else.
    ___________________
    Thecrewmanbloke
  6. #31
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    In actual fact....the correct placement for the microphones in the VY-VZ is right behind the rearview mirror. If you look behind there you will see a little notch cut out for the wire to run through. This place provides the ultimate placement for noise reduction and also allows the passenger to talk on the phone as well.
  7. #32
    madOne Guest
    Good Thread. I read this as my introduction to the JustCommodores fora. I got the parts from my local Holden dealer and I have a Nokia CK-1W coming. When I have everything I will pull aprt my SV6 and have a go.
    I got these parts so far
    GM-92172331 Phone Switch
    GM-92143075 Connector-Phone
    GM-92141210 Terminal Phone
    GM-92114020 Bezel,Hazard WR (has two openings, SV6 has T/C Switch)
    I'll take some photos as I go and post the link here.
  8. #33
    VZ SV6
    Jan 2006
    madOne,
    When you go to install the bluetooth kit, you will find that the T/C swith has a plastic lug that requires it to be in the bottom L/H postion of the console.
    Get a file and remove the lug so that you can move the T/C to the top left and the Bluetooth button in the top right.
    I installed the Holden Bluetooth Kit for my Nokia Phone and it works great.
    Let me know if you are after any other info on the install.
  9. #34
    VZ S Pack Ute
    Jul 2005
    Griffith, NSW
    Quote Originally Posted by madOne
    How did the install go? Ive got a carkit (not bluetooth, but the cradle one...cant remember the product code...genuine nokia one), and it has the little button that you can answer, hang up and do the voice tag thing with (see pic attached). i want to destroy the button from the kit and wire up a fixed holden button. I assume this is the same thing your doing?
    Looking forward to seeing some progress pics of your job
    Attached Thumbnails Attached Thumbnails VZ mobile phone car kit-phone-cradle1.jpg   VZ mobile phone car kit-phone-cradle2.jpg
  10. #35
    2004 Monaro-2010 VESSV Ute-2010 Kawasaki JetSki
    Jan 2006
    Quote Originally Posted by bern5
    what is the carkit or phone i need to get to work with the VZ radio?
    u can just plug it in, ??
    does any one know ? or can shed some light if they have already done it...what i need to get /do..
    thx in advance.
    I just had the Holden Bluetooth car kit installed by Holden. There is no mucking around with it, one button operation, radio is muted when activated and as soon as you turn the ignition on it activates the operation of the phone.
  11. #36
    monaro vz
    Sep 2005
    One of the best Blue tooth kits is a Parrot Evo it will work with most Phones it is available from Expansy among other places brand kits are usually only guaranteed to work with there own. Go for the Holden one.
  12. #37
    Jan 2006
    Quote Originally Posted by chev52
    I have to disagree there, I think the next model up is the one to get: the Parrot CK3100. You get an LCD display which gives you automatic phone book sychronisation with Caller ID etc. Something even the Holden one can't give you. Have a look at my post in the following thread Phone wiring for some pics, quite a neat install in my opinion.
    Z
  13. #38
    gunnie2745 Guest
    If you are after a kit with an LCD display I'd highly recommend getting the Parrot CK3200LS. This is a later (and better looking)bluetooth kit than the Parrot CK3100 that has a colour screen. Easy to install, great features, and able to connect to lots of phones. Got mine from Cellular Spares for $275, works like a charm.
    http://www.cellularspares.com.au
    http://www.parrot.biz/products/index.php?id=3200
    madOne Guest
    Default Replacing Nokia CK1W with Parrot CK3100
    I have had the CK1W installed for a while. I never have got around to wiring the Holden button in. The sound qaulity on the call as often very dissapointing, with me and the person on the other end of the call hearing an echo. So I now have the CK3100. It is a more complicated kit with more wires than needed. Has anyone put one of the Parrot CK3100 or above kits in before and worked out what goes where?
  15. #40
    Jan 2006
    It really is quite simple. As you worked out you don't need all the wires and the mute relay cable (that big black plastic thing) that the CK3100 has as the Blaupunkt stereo in the Commodore has full carkit integration.
    Look at this thread Mobile Phone Connector Details for the wiring connections in the Commodore and map it to the Parrot. The rest you don't need. The wires in the parrot should be labeled with tags.
    Since I might want to remove the parrot at a later date I did not want to cut any wires so I tapped in the 12V permanent, 12V accessories and Ground from the parrot cable. It already has separate line-in and mute wires. I then connected the male and female ISO connectors together so that I can neatly bundle the wires together and wrap it all in electrical tape so that it does not get in the way.
    Hope that helps,
    Z
  16. #41
    Jan 2006
    .... and one more thing, you can go to Phone Wiring where I have posted some pics of my CK3100 install.
    Z
  17. #42
    VR
    Sep 2005
    Default Nokia Vrs Every Other Brand
    The CK-1W doesn’t work well with non nokia smart phones (blackberry, O2 etc) the reason is the mic in the handset is going and the mic in the car kit is going at the same time!? the other drama is the mic being too close to the speaker (nokia recommends a min displacement of 1mtr) hope this helps some one out.
    Now for my drama, I have a CK-1W in my 95 VR, when I use it with my Samsung E730 it some times crashes the phone? ive solved this with the mod below. all is does is hold the acc. line above 4v while im start`n the car (if the acc line falls below 4v the carkit sees the ignition as off) now it connects and disconnect like my MRS nokia handset
    Parts were purchased from Jaycar
    1N4004 Diode - ZR1004 @ $0.40
    4.7uf 50V - RE6020 @ $0.22
    REMEBER TO CONNECT THE CAP THE RIGHT WAY AROUND, THE STRIPE ISNT THERE TO LOOK PRETTY
  18. #43
    VZ Berlina
    Oct 2008
    Default Installing a CK7 Blue tooth car kit
    Hi
    I am installing a nokia CK-7 car ki. So far I have the wiring correct for the constant 12v, the ign 12 volt , the earth and the radio mute. I am left with 2 blue wires which from the messages below are the audio+ and audio-.
    My delima is what do I need to do with thse two wires to have the car kit play through the radio speakers. The CK-7 box as a single jack connectoion for a seperate speaker. How do I take these two blue wires and connect them back to the single jack on the nokia unit.
  19. #44
    Jan 2006
    Quote Originally Posted by raggett View Post
    Hi
    You will need to buy a suitable plug from a place like jaycar and connect it to the blue wires. Its been a while since I saw one but I'm pretty sure those that originally bought the CK-7W usually included the speaker so all they did was cut the cable and gave the speaker back to the customer to throw away.
    Z
  20. #45
    Lumps of cheese's Avatar
    Lumps of cheese is offline catch us if you can Lumps of cheese ClubSport Lumps of cheese ClubSport
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
  21. #46
    Torquative's Avatar
    Torquative is offline go in Luxury Torquative Caprice
    5.7 Barge and Cross 6 Adventra
    Jun 2005
    I might have asked this (I might not have either) but where has everyone been mounting the nokia module?
    currently ive got it shoved in behind the radio cradle in that open area, surely theres somewhere more suitable because obviously it moves (and yes i'll admit its not secured to anything) where it is as when I hit the brakes hard it disconnects from the phone.
  22. #47
    Nov 2005
    Warrnambool
    Quote Originally Posted by Torquative View Post
    Behind the glovebox. Mine is secured there with cable ties, doesn't move and no rattles.
  23. #48
    Torquative's Avatar
    Jun 2005
  24. #49
    Torquative's Avatar
    Jun 2005
    well I found a good spot quite by accident. Theres that rubber mat area between the gear stick and that fold down area thingo on a VY/VZ, well just in under there is a spot thats the perfect size for the Nokia module to sit! Theres a metal bracket under there.
    I put some double sided tape on the module and taped it in place (had the center console out tho). Will upload a photo tomorrow for anyone thats interested
  25. #50
    bigfut's Avatar
    bigfut is offline Ve Driver bigfut Executive
    Ve Omega
    Jan 2008
    Ballarat VIC
    Quote Originally Posted by hsv_punk View Post
    Does anyone know, or have a bluetooth carkit with an external antenna? Because the added clarity and range of a external antenna would be another bonus with a car kit.
    I have a CK7W Nokia bluetooth kit, I bought a Nokia Cradle to suit my phone, and that had an external aerial plug coming off it, just fed that through to the external aerial, and hey presto all done, phone still is connected via bluetooth, but I just throw it in the cradle to boost the signal. Cradle was the CR-56 if you wanted to google it.
+ Reply to Thread
  1. Wtb: Mobile Phone!
    By cruzncommo in forum Swap / Wanted to Buy / Trade
    Last Post: 22-11-2007, 11:46 AM
  2. Mobile phone
    By Shounak in forum The Pub
    Last Post: 04-05-2006, 12:20 PM
  3. The Mobile Phone Jammer
    By MOTIV8 in forum The Pub
    Last Post: 02-05-2006, 02:14 PM
  4. Mobile Phone?
    By aperfectcircle in forum The Pub
    Last Post: 27-04-2006, 06:43 PM
  5. Mobile Phone Car Kit
    By death-from-above in forum General
    Last Post: 30-04-2005, 07:03 PM
