I am not sure what you mean. I have a Nokia CK-1W Bluetooth kit installed, and they are all basically the same. If the car kit has an audio mute wire and a mono out (for speaker) you should be able to mute the stereo and output the audio through the car speakers.
When you open the glovebox, you can access the harness for the mobile connectors through the right hand side there. Check your blaunpunkt manual for more information and wiring diagrams.
I noticed in another thread you mentioned WinMX for the VZ workshop manual - can you shed any more light on that one?
LinkBack URL
About LinkBacks
. I am going to look at some stage at a replacement button for next to the power windows, atm mine is under the set/mode button dial.
, which I promptly told him to put aside.
, with sound through the radio, Car Audio Mute working, and no wires cut (including the Audio wires). Everything can unplug and return the car back to stock if needed.
