Results 1 to 14 of 14
Thread: Vz Misfire!
    May 2004
    Default Vz Misfire!
    Hi there, I have a 99 VZ V6, 105k, which is misfiring intermittently. It is smooth after startup for about 30 seconds then misfires and idles rough, if I drive for a bit the problem is still there but goes away from time to time when idling. (but never completely!) No error codes or messages at all. Has anyone got any ideas? Would greatly appreciate it. I'm off to check hoses. Thanks!
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    99 VZ??
    When where the spark plugs last changed? Could also be a bad batch of fuel you've picked up, run some Wynns injector cleaner through it if thats the case.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    If you have a faulty plug lead or leads you will also experience a miss problem.
    VZ Calais
    Jul 2009
    i had that with my calais not too long ago - a couple of weeks after i changed the plugs, and a day after holden serviced it...sus much???
    i couldn't work out if it was the fuel or coil packs but after loosning and re-seating all the coilpacks it was fine... it was very weird and annoying tho
    May 2004
    sorry i meant 06 VZ! Thanks for the help, will go round the plugs & leads next.
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by Sean880 View Post
    VZ's dont have Leads, they have electronic coil packs. In place of the older leads & distributor cap.
    The Blue One
    Quoted for truth
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    It's probably a vaccume leak or your spark plugs, check your intake manifold bolts are tight enough.
    I had this once when changing my sparkies...
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    VZ SV6
    Aug 2008
    i got the same prob and diagnostics showed something wrong with injector circuit on cylinder 6 ? still dodgy fuel i dunno?
    May 2004
    Thanks for the replies, just changed all the spark plugs and no difference. Perfect idling for about 30 seconds when cold, then rough idling & acceleration most of the time. Will keep testing thanks......
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Have u tried process of elimination. Unplug each injector one at a time & see which one makes the difference or no difference
    The Blue One
    Quoted for truth
    VZ SV6
    Aug 2008
    May 2004
    Thanks for all the replies, the VZ is finally fixed! I eventually gave up and took it to Ultratune, coil pack #2 was dodgy and they replaced it. Runs perfectly again!
    $132 for the replacement coil, $130 for labour and $60 for a new metal inlet gasket. So about $320 all in, not a bad result I guess (Holden quoted me $195 for just the coil!)
    Now I hope the other 5 hold out........
    VZ SENATOR
    Mar 2009
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Yep. Just picked half a dozen coils from the same Seller, together with a set of Bosch Platin plugs and a pair of front O2 sensors.
    That should give my VZ a tickle up & help with the fuel consumption.
    Just got to grab the metal inlet gasket for a VE and figure out how to fit 'em up.
LinkBacks (?)
  1. 28-11-2010, 05:31 PM
  1. V6 misfire - where to next?
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2010, 04:34 PM
  2. VN misfire
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2009, 08:49 AM
  3. Vr Misfire
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2009, 07:50 PM
  4. Misfire ????
    By ecotec38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2008, 07:01 AM
  5. misfire
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 11:08 AM
