Results 1 to 5 of 5
Thread: intermitting faulty injector circuit on cylinder 6????
    VZ SV6
    Aug 2008
    Default intermitting faulty injector circuit on cylinder 6????
    at 1st you would think its a dud coil pack but the problem goes away? or a injector with crap in it? but after adding a injector cleaner and got the car put on a diagnostics the warning coming up is faulty injector circuit on cyl 6.
    took intake manifold off and checked all the wiring connectors and it all looked good.and the problem comes and go it aint constant. also i got no error codes or lil engine light on all i got was check powertrain. you think it be more descriptive seeing the car is littered with sensors.
    any help be great.
    thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Possibly a loose connection or a bad earth. Could even be the plug itself.
    Visit my Facebook page
    vz crewman s
    Mar 2010
    i have the same problem and discovered that it is not the injector, coil, plug, or wiring but the ecm not sending the earth to the injector to open and close it, from what i have read on here it it about 1000 bucks for a new ecm, SUCKS!
    VZ SV6
    Aug 2008
    yepp you got it waker46, just spend a grand on a new ECM. and to make matters even more of a head ache its got to go to Holden for programming because they still got the monopoly on the diagnostics,although my mechanic can do 80% of the whole diagnostics.
    VZ SV6
    Aug 2008
    problem fixed close thread please,
  1. Circuit Racing
    By wannaford in forum General
    Last Post: 22-09-2009, 08:41 PM
  2. VT airbag open circuit?
    By johnandles in forum Electrical Wiring / Questions
    Last Post: 17-04-2009, 08:41 PM
  3. My sub is an open circuit??
    By davway in forum Car Audio
    Last Post: 11-02-2009, 08:16 PM
  4. audio circuit breaker
    By matrix in forum Car Audio
    Last Post: 21-08-2005, 12:09 PM
  5. ECCS circuit diagram
    By hertygerty in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-02-2005, 07:58 PM
