Results 1 to 3 of 3
Thread: Installing a VDO Dayton MS5400 sat nav...
    VR V8 BT1
    May 2006
    Default Installing a VDO Dayton MS5400 sat nav...
    Hey guys i picked up a complete factory MS5400HD system from a VY and plan to install in my VZ Calais. Would anyone have or know where i could find some instructions on how to install this ? and where things go ?where to run wires ect..?
    Any helpwould be appreciated, thanks
    VR V8 BT1
    May 2006
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Quote Originally Posted by mattakaspeeedy View Post
    Hi I just did the exact same in my VZ Monaro. The computer goes in boot LHS under parcel shelf. I put the antenna on Drivers side dash top as I have Metallic Solar film on Rear glass & if you put the antenna on rear parcel shelf it may not get a good signal. I ran the loom from the dash unit to the computer down thru the centre console & under rear carpet & under rear seat into the boot area. I used the Acc +ve wire from the under dash Cig lighter plug . -ve to any metal earth point of dash. You need to get to loom behind speedo cluster & carefully bare the Speedo Signal wire (purple) & solder in your GPS speed input wire there & tape up. Use the Cig Lighter illum lt wire for GPS light day/nite signal wire, You may need a Hot +ve input, I ran a wire thru to fuse box under dash & connnected it there to one of the hot +ve fuses. (I know theres supposed to be a full GPS harness connector behind the glovebox somewhere & the harness is supposed to run along pax side door sill , but my method is easier & I didne know what wires were what on the factory connector) Hope that helps,
  1. Installing VDO Dayton 5400 in a VZ
    By thunder1234 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-02-2012, 11:27 AM
  2. [VIC] Vdo Dayton Multimedia Centre With Reverse Camera (plugs into your holden Nav system)
    By mccar13 in forum Parts And Other Items For Sale
    Last Post: 22-03-2010, 06:49 AM
  3. [VIC] 20" Dayton Wires
    By Oken in forum Parts And Other Items For Sale
    Last Post: 08-02-2009, 05:52 PM
  4. vs vdo dayton sat nav cds
    By wombat_831 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-01-2009, 08:00 AM
  5. Replies: 7
    Last Post: 19-12-2005, 11:06 AM
