Results 1 to 9 of 9
Thread: Vz alloytec rough idle
    Vz Commodore
    Mar 2010
    Default Vz alloytec rough idle
    Hey fellas just wondering if someone can help me out,
    I just did a service on my VZ executive. I started it up and it ran fine. Reversed it out and turned it off. I then tried to get rid of the service notification. Started it up and it started to feel like its miss firing/knocking or something its just not running well. when i rev it revs fine. but at idle its just not healthy. Its coming up with a powertrain fault
    I did the K&N filter and thinking that the oil might be stuffing one of the sensors around but would this rough idle be making it do that ?
    Anyone had a problem like this before?
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    similar problem had too be, just had to reset the computer. unplug your battery for 10 minutes then plug it back in.
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Yep, had the same problem.
    I changed the plugs and it came healthy again. Check your gaps and change if necessary. It also pays off to check the exhaust system for dents or kinks in the components. Bad flow of gasses can lead to a bad idle.
    Vz Commodore
    Mar 2010
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    i got a ex fleet wagon on gas. whenever i give it a bit of stick, i get the "check powertrain" on the dash display, and it shakes and misses as though i done a head gasket or arnt firing on all cylinders. pull over and turn off the car, then immediately start it again and it idles and drives perfect again as long as i dont go close to or floor it. the exhaust under the tranny is slightly bottomed out, but surely this couldnt be causing it? its got 115000km on it and im about to do a full service in the next week, cos if the fleet mechanic is goin by the log book he would change sparkys every 120000km.
    anyone experienced this?
    Feb 2007
    Quote Originally Posted by mattyr82 View Post
    Yup. LPG is a LOT more demanding on ignition components than petrol is. Spark plugs won't last 2/3 as long as they would on petrol. 80,000km is already pushing it. Get the plugs replaced ASAP with Bosch double platinums gapped to 1.1mm and while you're at it, replace the oxygen sensors.
    Injected CNG, LNG & LPG: The only way to go better!
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by poweredbycng View Post
    ok thanks poweredbycng do u think ngk are better than bosch they are are bit more expense than bosch at the parts stores? should i change coils as well? cheers
    Feb 2007
    Nah, Bosch double platinums are less demanding on other ignition components as they wear and are BETTER than iridiums for LPG applications. As for coils, change them ONLY if you are having issues. Don't forget to use dielectric grease to ensure that you don't get any spark leak. The double platinums will also last LONGER than iridirums for LPG applications.
    shozzy's Avatar
    shozzy is offline "Licked by janitor"
    VZ executive 3.6
    Aug 2008
    Kallangur, QLD
    this happened to me and i thought it was the O2 sensors but it turned out to be a coil pack... best to check what the problem is before replacing the sensors as they dont exactly come cheap...
    Go for gold, if not gold go for bronze, it's golder than silver
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. VZ rough idle fix
    By f1tzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-06-2009, 01:01 PM
  3. VS rough idle
    By greenvscalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 04:56 PM
  4. Rough Idle
    By chum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2005, 09:36 PM
  5. Rough Idle!!!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 01:43 PM
