Results 1 to 5 of 5
Thread: Active select paddles not working
    N/A
    Nov 2009
    Default Active select paddles not working
    Hi,
    I recently bought a 2006 VZ SV6 commodore and realised that the active select paddles don't work or won't change the gears. When i activate the active select mode and press the paddles nothing happens, then when i deactivate the active select i am unable to reactivate the active select mode again. It seems like the car is detecting a fault and not letting me reactivate the active select.
    Has anyone had this problem before?
    thanks.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    does your horn work?
    if so, someone has fitted the wrong clock spring to your car.
    I had this prob when mums partner fitted the wrong one, didn't believe me and it cost him the replacement
    Chev badges are an instant fail
    N/A
    Nov 2009
    My horn does work.
    What is the clock spring, how do i know exactly if the wrong one has been installed and how do i go about putting the correct one on?
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    the clock spring is basically a coil that gets power to the steering wheel.
    I cant comment on what the differences are between the range cos i didn't see the old one come out.
    It will be easier to get holdens or an auto elec to do it because the airbag and steering wheel has to come off
    The other thing i just thought about, have you or anyone else replaced the steering wheel controls?
    the reason i ask is that the sv6 and calais have a different loom for the controls
    N/A
    Nov 2009
    I probably take it to holden and see what they say. I dont kno if it was replaced becuase i just bought the car a few weeks ago.
    Thanks for your help.
  1. will an sv6 steering wheel with paddles (active select) fit an executive??
    By SKNOT9 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-02-2010, 08:15 PM
  2. VE SSV Transmission - Reprogramming to mod Active Select?
    By RustyCardores in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-10-2009, 12:13 PM
  3. How's the Active Select?
    By PhantomSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2009, 07:17 AM
  4. Active Select acting up (i think)
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2007, 05:03 PM
  5. VZ Adventra Active Select
    By AWD_VZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-11-2005, 09:41 PM
