Results 1 to 2 of 2
Thread: Leaking diff seal
    vz equipe
    Sep 2006
    Default Leaking diff seal
    Looking for advice please.
    I picked up some fencing wire around my prop shaft on the Newell highway and needed NRMA to remove it as my Leatherman wouldn't cut it loose. It was wound very tight and when it was removed the guy said I may get a leak around the shaft which was correct. 500 ml used between Forbes and Melbourne. The metal flange type thing is also damaged, this may just protect the seal but I am not sure.
    Is it a straight forward job to fix this or is it a job for pro's?
    Any help appreciated,
    Cheers, Rick
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    Really rotten luck.
    I have disassembled a few diffs and I definitely would not tackle this job yourself for many reasons but especially as the full scope of the damage might not be clear.
    If it were my car I would take it to a reputable diff specialist that knows these commodores.
    Best of luck with it.
  1. Help rear seal won't stop leaking in v6 Vt
    By Ralphie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2010, 07:18 PM
  2. Rear Main Oil Seal Leaking
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-03-2009, 02:04 PM
  3. Rear main seal leaking after Supercharger
    By timbra_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 09:40 PM
  4. LPG Converter seal leaking coolant!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 10:37 AM
  5. Vr - Rear Main Seal Leaking
    By Fatboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2003, 06:41 PM
