Results 1 to 8 of 8
Thread: Can not get bush/metal shell out of end of control arm!!
    SKNOT9 is offline All hope is gone
    VS series II Acclaim
    Feb 2007
    Lobethal, South Australia
    Default Can not get bush/metal shell out of end of control arm!!
    I just cant seem to get the metal sleeve out of the ond of the front control arms!! im putting in some urethane bushes. Ive tried everything, punching it out with a chisel, smacking it out with a hammer, various methods tried with a vice. i just cant get it!!! anyone know how to do this??
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Sknot9
    If you have removed the rubber, and only the outer steel shell is left in the control arm, you can remove it by sawing it through with a hacksaw, then driving one side of the cut in towards the centre of the hole. ONce the shell has been cut, the tension is removed and the shell is much easier to remove.
    Simply place the arm in a vice, leaving the inner end nice and clear to work on. Remove the hacksaw blade from your hacksaw, pass it through the bush, then reconnect the saw handle. Tighten the blade up as far as you can and cut the shell nice and flat so that you cut through it evenly, and don't actually cut the arm.
    Feb 2007
    Thumbs up
    thankyou, that sounds like it should work!!!! i hope it does, ill let you know!, thanks for the advice!
    Feb 2007
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    getting a new one back in will probably be harder that getting the old one out ..not sure if urethane ones are hard to get in...the harsh ride they give and how they tend to move make rubber ones a better prospect .....with my vr I gave up before I hurt myself.......just went down to the local pedders and got someone there to press the old rubber ones out and press the new rubber ones in for a few bucks
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    I replaced all the rubbers front and rear in my VR a few years ago, using pullers and press plates I made up myself and a heavy duty vice. It was a shit of a job with a couple of bushes that didn't want to co-operate, but I managed to replace every one over two weekends. What a difference it made, as the car had done over 280,000 at the time and some of the bushes were absolutely r.s.
    Feb 2007
    putting the new one in was fine as it was a fully urethane bush rather than having a metal shell
  1. How do I remove my lower control arm? or pivot bush.
    By VT_sleeper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2009, 06:17 PM
  2. Lower control arm rear bush ????
    By surfer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2009, 05:37 PM
  3. [VIC] VY - Urathane Control arm bush and Sway bar link
    By hrforever in forum Parts And Other Items For Sale
    Last Post: 17-01-2009, 07:40 PM
  4. How to Replace Control Arm inner bush - Superpro
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2009, 02:21 PM
  5. FS: Control Arm -> X-Member Bush (NZ)
    By Anthraxnz in forum Parts And Other Items For Sale
    Last Post: 18-10-2008, 04:02 PM
