Results 1 to 22 of 22
Thread: VZ SV6 New exhaust system and car started overheating...any ideas why???
    VZ SV6 but have owned VC,VK,VL,VP,VT
    Sep 2009
    South East Queensland
    Unhappy VZ SV6 New exhaust system and car started overheating...any ideas why???
    I got a new exhaust system put on and drove 150km when I arrived at my destination the temp gauge was up and a bubbling/boiling sound was coming from under bonnet. I contacted exhaust shop but they denied it could be anything they did. I have had NO previous cooling issues with car.....what has happened????? Can anyone help
    VT Berlina S2 V6 + VZ Acclaim Wagon
    Jul 2005
    Hi,
    Was just wondering how much of the exhaust was replaced? Was it cat back or closer to the engine?
    Sep 2009
    Red face
    Quote Originally Posted by BerlinaBen View Post
    Hi,
    drivers side cat was replaced then single pipe 2.5 Sports system -I was told they didnt touch anything near the engine. Have driven car short distance since and no overheating....but will see if it happens on next big drive..do you think its exhaust related or a bad coincedence and something else has gone wrong?? Mechanic will be checking it out on weekend but wanted advice from here
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Dodge radiator cap perhaps, mine overheated once and found it to be the problem
    Life starts at 200km/h
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    I can't see it being exhaust related so its probably just a bad coincidence.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    ^^^ Same here.
    MissSV6, check ur radiator cap, there's a possibility that the rubber ring on the underside of the cap has worn.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Maybe they disconnected the battery to do some welding on the exhaust , then when reconnected it may have blown a radiator electric fan fuse or the fan relay????
    VY Calais
    Jan 2010
    mine overheated on the way to the exhaust shop haha, Check your top and bottom hoses? Check the hose rings. My Radiator blew a few days later.
    sounds like its just a coincidence it happened after you had your exhaust done
    VY Calais, LS1, 19's, Lowered, VY2 Front bar.
    2009 VE SS SILVER SEDAN
    Sep 2008
    Brisbane, Queensland
    Quick thing you can do, start the car when it's cold and run your hand around the exhaust joins just under the car..... make sure they are sealed..... i cant remember which way it goes if they leak, lean or rich etc. but an idea just to check anyway.
    but it's probably unrelated. a change in exhaust can change pressure, may bring on more engine knocking?... which does heat the engine. I doubt it'd be anything like that.
    check the exhaust is sealed, then check the radiator cap i recon.
    2009 VE SS SILVER SEDAN - Twin Amps... Tune in progress (more for response and power) then outright KW on a dyno
    Jul 2005
    Yeah, I was gonna suggest the Oxy sensor but I think from memory it's located closer to the engine. Was thinking if something had happened to it the ECU may be leaning out your fuel mixture?
    Ben.
    Sep 2009
    Thanks for your replies. The problem was the high speed cooling fan...I didnt realise they wernt even going ..just something you get used too. The line was burnt out and has been replaced along with the fuse...so hopefully thats the end of it...mechanic reckons its unrelated to the exhaust. But I still think its a bit weird that it happened same day.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    one of those bad coincidences
    like when the car plays up everyday .... except the one that its at a mechanic!
    Theres no way the exhaust would affect the cooling fan, its like saying the bananas went off at Woolies because the milk in the fridge had expired
    Sep 2009
    UPDATE: Turned on car this morning and gave it some revs and water came out of exhaust...please tell me its not the head gasket!!!Ok...so the fan has stopped working again it got really hot yesterday while on a drive and you could hear the bubbling when I pulled over. The relay and fuse were replaced on Friday and it had a service and tune up. The fan comes on when the aircon is running but otherwise not.....what do you think the prob is. Car is going back to mechanic tomorrow.
    Sep 2008
    water can be normal..... it's mostly dependant on where you live.
    If it's cold your car was probably hot when u turned it off, and the heat/steam formed condensation i wouldn't worry about that really.
    Its pretty normal...... my car when it was stock used to do that in winter.
  15. #15
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    water from the exhaust is not a problem. if it was a head gasket it would be blowing white smoke when you drive ... =) its ok breathe and relax haha
    the fuse might be blowen again? there could be a short in the electrical system somewhere ?
  16. #16
    Sep 2009
    After being at Mechanic and Auto Electrician they think the problem is now the thermostat..which is a pain in the ass to get too aparently
  17. #17
    Feb 2010
    Tamworth NSW
  18. #18
    Sep 2009
  19. #19
    Delish-VY's Avatar
    Delish-VY is offline Steve
    2003 VY S pack
    Jan 2010
    Originally - Eastern Suburbs - Melbourne, Currently - Cairns
    when you said overheating problems originally my thoughts instantly went to heater tap?, everybody I know who has a commodore is like...mate those heater taps are shithouse keep an eye on them which im happy to believe because I had a vectra (p.o.s) and its heater tap blew...cheap enough to replace but a pain in the butt
    My VY S-Pack
    Quote Originally Posted by wraith View Post
    Don't ruin a good story with facts.
    Pet Peeves - V6 Modded Exhausts - Rims on Front/Stockies on back - Chev Badges - Kitted cars with trolley strips - Fusion & it's fanboys
    Having less rights than a balinese prison
  20. #20
    Feb 2010
    Tamworth NSW
    hey could be worse ... could own a ford and have a car that bearily runs haha :P
  21. #21
    Delish-VY's Avatar
    2003 VY S pack
    Jan 2010
    mate if I owned a ford I would rather it didnt run that way I wouldn't be seen driving it!
    My VY S-Pack
  22. #22
    Feb 2010
    Tamworth NSW
    ^ hahaha true point that one
  1. VR Ute System Ideas...
    By Uber_Flacky in forum Car Audio
    Last Post: 19-11-2009, 04:50 AM
  2. It started with overheating.....
    By t0mm0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 01:15 AM
  3. New System Ideas - HELP!
    By Jesterarts in forum The LAN Lounge
    Last Post: 18-11-2008, 10:54 AM
  4. VN Exhaust System Ideas
    By 91VN84km in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 12:46 AM
  5. VX leaking oil onto exhaust manifolds after not being started for a long time
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 09:54 PM
