Results 1 to 4 of 4
Thread: Climate Controll problem
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    Default Climate Controll problem
    Hi everyone, i noticed a while back that my 05 VZ Berlina blows hot air when the climate control is off, and i have no idea why... my mate has just bought a VZ Clubby and his does the same thing, any ideas?
    Thanks
    Greg
    Mar 2010
    Whyalla SA
    I should point out that its only when im driving, so i am thinking it is just a valve not shutting completely but i don't really know where to look
    05 VZ Berlina
    Mar 2010
    Could the heater tap in the engine compartment be stuck open? Or no vacuum going to it? No vacuum would mean it stays in the open position.
    You could test by putting the temp on H then on C - the tap should close for C. If it doesn't, take the vac hose off the heater tap while running - see if there is vacuum there.
    Even then, the mixer flap in the cabin should close shouldn't it? Maybe that. Or the vacuum solenoid pack.
    And see my rant here
    Calais climate control on 'AUTO' throws to demister when uphill grade ?? vacuum issue
    for more links.
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    Mar 2010
    Whyalla SA
    oh well it shouldn't be the heater tap because that was just replaced, and the hot air stops it the fans are turned on so its a bit strange but its really starting to annoy me :P, so im thinking the mixer flap is probably the issue
  1. climate controll coversion
    By shaggy0001 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-12-2008, 11:56 PM
  2. Worth to change from manual air control to Climate controll
    By Damo83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 10:15 PM
  3. Climate Control Problem
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:16 PM
  4. Vt Executive Cruise Controll Problem
    By badly_drawn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2005, 02:02 AM
  5. Vx Calais Climate Controll
    By lachlanmac23 in forum Electrical Wiring / Questions
    Last Post: 07-01-2004, 03:13 PM
