Results 1 to 13 of 13
Thread: VZ Steering wheel buttons illumination.
    VZ acclaim Wagon MY06
    Mar 2010
    Default VZ Steering wheel buttons illumination.
    Hi all, just new to this site and have found it be full of great info. My question is, are the buttons on the steering wheel supposed to illuminate when you turn your headlights on? Mine don’t. I have just installed a Pioneer head unit with a CAT 10 and thought maybe I had done something wrong to cause this, however I’m also thinking it would have nothing to do with the lighting. I can’t say I paid too much attention to whether or not they illuminated before I installed the head unit.
    Grant.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Mine in the ss do, but they didn't in my old vy berlina.
    From what i'm told only the calais and models above have it, as do the ss.
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    vz sv6
    Apr 2008
    Depends on the model of and transmission. SV6 auto has lit up buttons because of auto shifter paddles on steering wheel.
    VZ Berlina
    Aug 2004
    5.7L VZ
    Jan 2010
    Nthn Beaches, Sydney
    I think the general rule of thumb is that if it has steering wheel paddles, then the radio controls light up, if they don't have the paddles then they don't (from what I understand anyway).
    VXII Berlina 5.7L / VW Golf GTi
    Mar 2009
    South-west Sydney NSW
    Quote Originally Posted by Tnarg78 View Post
    Grant.
    The other guys are right. It was only certain models in the VZ which did light up, mainly the Calais, SS and SV6 auto (due to the flappy paddle gearbox on the wheel). Unfortunately the Acclaim, like yours, do not light up. If you wanted them to light up you would have to purchase the switches from one of the models that did, then get them wired up. Pain in the a*** if you ask me, but it can be done.
    There are 2 types of pedestrians, the quick and the dead
    Check out my ride here....
    http://forums.justcommodores.com.au/...rlina-ls1.html
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    from what i know only the higher models have it like HSV & berlina etc. i wanted them on my executive but i couldnt get them
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Only the 5 speed automatics (since they have the paddle shift) have the illuminated steering wheel controls in the VZ's from what ive been told.
    Mar 2010
    Thanks for all the info fellas, most appreciated. It’s strange that they didn’t make them illuminate standard, however I’m sure I can live with out them doing so.
    Redline SSV
    Jun 2008
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    I just converted my VY to the illuminated controls , not an easy job but I did it using a WL clockspring & WL illuminated buttons, & a wiring harness plug & 100mm of harness from a wrecker off a VZ with the paddle shifts, that taps in to the VY harness & plugs into the rear of the clockspring. The WL clockspring needs to be "altered slightly" to fit on the VY , A couple of bits of plastic need to be cut off where it hits. 2 extra wires need to be run down to the BCM & spliced into the wiring to get your +ve & -ve for the illumination dimmable circuit. You need a VY & VZ wiring manual/s (ellery's is a good one). Be carefull with the airbag (disconnect battery , ) & make sure the clockspring is centered turns wise when you fit the steering wheel , (2 1/2 turns from centre either way to each full lock) . Not for the amateur this mod but if youre a Techie or a Hobbyist supreme you can do it....
    VZ Executive
    Feb 2011
    Gold Coast
    i have a vz exec, it doesn't have illumation, cat10 is just for the pickup to the 3rd party head unit i thought, as a got a pioneer headunit with bluetooth, and had to have steering wheel support on the headunit to use the cat10 unit.
  1. Steering Wheel Buttons
    By vxseries1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2010, 10:30 PM
  2. Vy steering wheel buttons
    By m_unit in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2010, 07:27 PM
  3. vt steering wheel buttons
    By 90magpie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2009, 09:04 PM
  4. vx steering wheel buttons
    By beamer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2006, 09:34 AM
  5. steering wheel illumination
    By commy gal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2005, 08:43 AM
