Results 1 to 5 of 5
Thread: Interior Lighting
    VZ Executive
    Apr 2010
    Dingley Village, VIC
    Default Interior Lighting
    Hey guys, new to the forum please redirect me if this is the wrong place to be asking this. thanks
    Got a pair of neon tubes which i intend to put down near the driver and passengers feet (my car is a VZ Executive). Both of these neon's have connection to the cigarette lighter. My question is how do i connect both neon's to a power source without using the cigarette lighter?
    thanks in advance
    Chris
    svsex is offline big blue
    190 sv6
    Jun 2008
    just connect them to the power supply for the cigarette lighter, might be a little stone age but should work, might blow a fuse if u plug spmething that draws a lot of current into the cig lighter
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    and if it blows you just put a bigger fuse in, then everyones happy =)
    im bout to put two neons in my car and i intend to do the same. just cut the connection off, and wire it into the power sorce for the cig lighter
    ( im putting them under my seats so i get the frount and back =) )
    vh
    Dec 2009
    take off your plastic around the steering wheel and stalks and find the wire that connects to the headlights and solder it on. then you have to earth it, i did on a nissan and earthed it on a blot near the door, it looks clean and no evidence of wries.
    you will have to cut off the button switch that you use to turn them on and off, this is the wire that connects to the headlights wire..
    So every time you turn your lights on your neon's will turn on too. Most professional way to do it.
    Feb 2010
    Tamworth NSW
    why don't you just take the dash and councoul off, and run all the wires with the other wires .. that would be just as clean and easier ....
  1. no interior lighting
    By qik42c in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2009, 11:08 PM
  2. vt interior lighting question
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2008, 12:55 PM
  3. Changing the lighting on interior
    By sik888 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 10:21 AM
  4. Interior Lighting Problems - VK
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 07:54 PM
  5. interior lighting
    By nervesplit in forum General
    Last Post: 29-11-2004, 09:58 PM
