Results 1 to 6 of 6
Thread: are the gear select letters meant to have a backlight on a vz
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    Default are the gear select letters meant to have a backlight on a vz
    or does the gear ur in just come up on the dash, dont want to take apart the console for nothing if it doesnt have a globe. sorry for the stupid question but never seen a vz before now.
    VZ SV6, VL (Speedway)
    Mar 2005
    Penrith, NSW
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Hinge down the fuse compartment & pull off the O/S cover only to the console..that's all you need to do to get access takes about five minutes.
    It takes longer trying to fit the globe.
    05 VZ Berlina
    Mar 2010
    Thanks for that tip. I've had the globe for a couple of weeks (it's just a clear one, not green) and haven't fit it yet. Will do soon..
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    05 VZ Berlina
    Mar 2010
    Just did it and was much easier just taking off the side trim than taking the middle console off which I was going to!
    Looks like a small 2W push in globe. Part 92145420 , about $2 I think it was.
    2005 VZ Acclaim
    Jul 2009
    Northern Beaches, Sydney.
    Yeah same problem with mine, there is no light where the it should show where the gears are : /
  1. Replies: 58
    Last Post: 11-07-2009, 11:42 PM
  2. is there meant to be oil on here?
    By fuzzy2308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 06:23 PM
  3. Is this meant to happen?
    By brentons_house in forum V6 Development And Modification
    Last Post: 27-06-2006, 07:51 PM
  4. How to: Install/ Remove gear select changer for auto trans
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2006, 11:42 PM
  5. Chain Letters
    By gsmrobinson in forum Jokes/Humour
    Last Post: 28-01-2004, 09:44 PM
