Results 1 to 5 of 5
Thread: Wouldn't start when warm, now won't start at all
    VZ Excutive
    Feb 2010
    Default Wouldn't start when warm, now won't start at all
    It all started when I was getting the svs (service vehcile soon) message.
    A search of the forums ruled it down to the oil pressure sensor.
    So I replaced the sensor ($80) and did a mini service. I replaced the oil filter, the oil, the air filter, and the fuel filter...
    I will come back to the fuel filter..
    Before the service the car would miss as it was going up hills or under heavy acceleration. I first thought it was the gearbox, but another search of the forums ruled it down to the spark plugs.
    Everything but the fuel filter was hassle free. When removing the plugs on the filter (should have done a forum search) I broke the "t" junction on the return fuel line assembly. Confused as to why there was a return from the filter, I figured that I could leave it disconnected infill I bought a new return line assembly.
    With all but the return line ready to go, I started the car after a few tries. And took it for a 15km test drive. No issues, in fact the big hill which was making the car skip, was no longer making the car struggle. The svs message also disappeared.
    Happy with the results. I used my car for the following week (80km a day) and noticed no issues. Until I parked the car after an hour drive, then tried to start it after 10 minutes of sitting. The car tried, and tried, and tried. I had fuel, I had spark, and I had compression. Eventually it flatten the battery. I waited about 30minutes, then it started on the second try. Over the next few days it would start if the engine was cold, but not even on a hot day.
    So I replaced the return line assembly, which involved dropping the whole fuel tank. And now the car won't start at all. I can't smell the fuel like I could when it was hot.
    I double checked all the plugs and lines. I even checked the air ducting between the air box and the throttle body. Only to find a heap of oil. Atleast 200mls!
    Any ideas?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Probably your crankshaft sensor. You can find it in behind the harmonic balancer - front of the engine. They often fail when they get hot. When you have trouble starting the engine, pour a cup of cold water over the sensor and if it's the cause of the problem, the engine should start. Replace the crankshaft sensor.
    VZ Excutive
    Feb 2010
    Default Fuel Pump
    Turns out my fuel pump is stuffed, we connected the diagnostic computer tool to the car and found no logged errors.
    Relay's and fuses for the pump are all ok, I will replaced the pump (whole assembly) on the weekend, i got quotes between $250 and $550 for the assembly, some dealers even with the same name quoted completly different pirces.
    I have a feeling that the warm start problem will continue, So i will try that trick with the crank angle sensor if it still has warm start problems.
    Shouldnt the crank angle sensor give an error?
    Thanks
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Benboy View Post
    that works good if you own a ecotec, but crank angle sensors are totally different setup and a type thats not common to fail
    Quote Originally Posted by karwalski View Post
    Thanks
    i dare say you would have been over pressurising the fuel system, so would have lead to the failure
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VT Executive S1
    May 2010
    im having this same problem, could it be my fuel pump that is stuffed....
  1. VY Won'r start while warm?
    By stealthVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2012, 04:22 PM
  2. warm start trouble
    By reardo_202 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 02:14 PM
  3. VR stuggles to start when warm??
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2006, 11:01 AM
  4. VY doesnot start when warm
    By RichardW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 12:32 AM
  5. VT does not start when warm
    Last Post: 22-03-2006, 10:00 PM
