Results 1 to 5 of 5
Thread: Electric antenna manual height adjustment
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Default Electric antenna manual height adjustment
    Hey guys, i have just replaced the mast of the electric antenna in my dads VZ calais and it goes up and down fine, but when its at its lowest point it sits into the guard about 1-2cm lower then the old one used to. Is there a fine tuning manual height adjustment to make it stop level with the gaurd in the black surround part
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    50 looks and no reply . Someone has to know if there is a fine adjustment on the Calais electric antenna? It works perfectly fine as it is. but it just goes down about 2cm more then it used to
    Dec 2009
    Are you sure the top of it it is fitted into the guard as high as it needs to be? I have not pulle done out of a VZ but in a VN you can adjust this height a bit. The Calais ones can be adjusted manually can't they? The only ones I have mucked around are either fuly up or fully down and I had one that would not go fully down I just took out the big gear that goes onto the mast and pulled the mast out a bit, put it back together and it found the correct position.
    sxc_sound's Avatar
    VT Series 2 S pak
    May 2008
    Parkdale
    yeah its all fitted into the guard properly. It does have the adjustment buttons on the head unit. But when you turn the head unit off the antenna goes down and it goes right into the guard about 2cm lower then level with the top as it previously did. ( it may sound minor, but dad is a perfectionist. So im just trying to get its lowest point about 2cm higher then it currently is)
    VZ Lumina
    Mar 2010
    tried pulling the fuse out for it when it's down to 'reset' it? i had to do that with a mazda i had once...
  1. Electric Antenna installation on standard/non Electric ant VN/VP
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2011, 03:38 PM
  2. VX commodore drivers side electric seat adjustment does work
    By liveline98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 08:54 PM
  3. Electric Antenna
    By tomyy. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2009, 06:51 PM
  4. Antenna Height Adjustment Module?
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2006, 04:02 PM
  5. Electric Aerial Adjustment
    By VPwagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-07-2006, 08:33 PM
