Results 1 to 3 of 3
Thread: L.E.D tail light fault with VZ utes??
    vz ute
    Apr 2010
    Default L.E.D tail light fault with VZ utes??
    i bought some altezza led tail lights. one side worked perfectly, but when i hook up the other side, the tail light fuse blows. we have tried the lamps in another car and they work fine. someone at work mentioned that because led's draw such a low current, u have to fit a resistor to compensate or the ecu will trip out.
    anybody had this problem???
    VZS-Ute06
    Aug 2006
    Western Vic
    you have a short somewhere i.e. incorrect wiring or a +ative wire with a bare patch toutching metal
    try hooking up the one that blows fuses on its own first
    VZ-Rob
    98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
    vz sv6t
    Apr 2010
    yea probibly shorting out, but i had the same problem and it messed with my cruise control and traction control. i had to get a pair of load resistors one for each side and wire them in and problem was fixed
  1. check Tail Light dash light on
    By egadgetjnr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2009, 11:43 PM
  2. [WA] vb-h tail wagon tail light and bumper
    By markovr in forum Swap / Wanted to Buy / Trade
    Last Post: 19-12-2008, 08:20 AM
  3. ve fault light
    By ptharris in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-10-2008, 09:23 PM
  4. Replies: 1
    Last Post: 27-09-2006, 06:58 PM
  5. Fault light came on but reports no fault
    By VRBerlina05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 07:21 PM
Tags for this Thread
