Results 1 to 6 of 6
Thread: Blown rear bulb fault
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Default Blown rear bulb fault
    G'day all
    First minor fault with the VZ. It comes up with warnings for a blown taillight when the lights are switched on, and for a blown brake light when the brake is depressed. Which would be fine... if there actually was a blown bulb.
    We've checked all lights. All taillights are working, as are number plate lights, and the three brake lights are also working when pedal is used.
    Checked the fuses, and they all seem fine. Spat out a warning for a "taillight fuse blown" when I removed the fuse, but that's obviously gone. Next port of call will be to get some new bulbs. For the sake of a few dollars to see if they fix the problem, and if not I'll have it checked at it's next service.
    Just wondering if anyone has a possible cause and/or solution for this?
    Damo
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Hows your Trailer socket??? Could have moisture in it or a shorting wire on the back of it.
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    Didn't even consider that. I think the connector might be in the boot as it's not mounted to the bumper, but it's worth a look. I'll check it out tonight after work.
    CruznCalais
    [GAMBLR]
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    I was getting the same warnings.
    It turned out to be the number plate light was intermittently going on & off due to a build up of dust in the socket.
    I pulled the globes out, dusted them off, reinserted and it was fine after that.
    GAMBLR's Avatar
    '04 VZ Calais LS1
    Dec 2006
    Ah cheers mate, will check that out too. Trailer connector seems to be fine and moisture free, and the taillights were replaced last night, still no go.
    CruznCalais
    [GAMBLR]
    VZ Calais
    Jul 2009
    i get that mostly at the traffic lights when im only lightly on the brakes. I've noticed that the brake lights don't come on til the car's actually being slowed down so it might be the sensitivity of the sensor for the blown lights but i might replace the other number plate light to see if that fixes it
  1. vs rear demister fault
    By stato v6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2010, 06:47 PM
  2. late model ute rear bulb replacement
    By Troy711 in forum General
    Last Post: 01-05-2008, 04:35 PM
  3. Blown Bulb indication
    By ivaninoz in forum Electrical Wiring / Questions
    Last Post: 17-09-2007, 09:28 PM
  4. vs statesman blown bulb warning light
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 07:22 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
