Results 1 to 11 of 11
Thread: Engine hesitant in first gear
    2005 VZ SV6
    Apr 2010
    Default Engine hesitant in first gear
    Hey guys, just bought a vz sv6 a couple of days ago everything is fine with it. however!
    I noticed when i boot it off the lights, its sortof like it doesnt want to go up in the revs and hesitates, especially above 5000rpm. It has about 118k on the clock, so im guessing it might be the spark plugs as they may have not been replaced. im going to do a service on it this weekend and change the oil, plugs, air and fuel filters and just go over the car.
    Any ideas what could be going on?
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    id prob do your service first, see how it goes if not then we will be able to narrow and rule out things
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VZ SENATOR
    Mar 2009
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    2005 VZ SV6
    Apr 2010
    alright i went for a drive today with a mate. we both came to the agreement that its missing so my first guess is that its the plugs...
    i know that the manifold has to be pulled of to do this but how do i go about doing it.
    VZ SENATOR
    Mar 2009
    This should help - only prob is the MACE guide identified one wrong screw on top (there is a big hole in the front left) the final screw is at the back. Check the second link
    http://www.maceengineering.com.au/We...TALLATION_.pdf
    http://forums.justcommodores.com.au/...assebly-91.jpg
    2005 VZ SV6
    Apr 2010
    Quote Originally Posted by mattsv6 View Post
    ahh yeah too easy mate
    also, if it is the coils. i have a feeling its going to be, what am i looking at in price to get those replaced (its still under 3 month statutory warranty so they should hopefully do it for me for free )...
    VZ SENATOR
    Mar 2009
    Your problem sounds very similar to mine mate - missing under load or at high RPM. Mine turned out to be the coils too.
    Go for the warranty option if you can, but if that fails I bought these from ebay and installed them myself GENUINE HOLDEN COMMODORE VZ V6 BOSCH COILS 3.6L - eBay, Other, Car Parts, Accessories, Cars, Bikes, Boats. (end time 08-May-10 14:18:55 AEST)
    If you do it through holden your looking at $100+ for each coil, so the DIY option can save you about $400. Hit me up if you need any help installing them as I'd be happy to give you any advice, found a way to get it all done without completley removing the intake manifold and splitting the gasket
    2005 VZ SV6
    Apr 2010
    oh sweet as. im 90% sure its the coils. the dealer better fix it (they should right?). however if they dont ill buy some off ebay, i worked as a mechanic for about a year and a half so ive got a pretty decent idea how to go about it. but some advice on getting the manifold out of the way would be great!
    thanks mate
    2005 VZ SV6
    Apr 2010
    hey guys, PROBLEM SOLVED!
    took it back the my dealer, they fixed a wheel bearing issue i had, did a diagnostic scan and the coil showed no problems. he recommended i just change the air and fuel filter, and plugs. plugs were fine (Y). the air filter hadnt been change since 2008 :S and im guessing the fuel filter was the same (pretty much completely blocked). i threw a k&n panel filter in for now. the car goes so much smoother and got abit more power!
    thanks for all your help guys!
  1. [SA] Wtb: Vq caprice less engine and gear box
    By SILVR VP CALAIS in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2010, 06:13 PM
  2. Engine and gear box change over
    By peeingeye in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 12:55 PM
  3. engine hesitating to drop down a gear at 60kmH HELP..
    By BIG-EV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2009, 07:02 AM
  4. knock, engine swap and gear box ^_^
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2008, 11:59 PM
  5. WTB: VL turbo. full car, engine, running gear.
    By Jason1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 19-07-2005, 11:56 PM
