What's the difference between the Holden VZ normal v6 motor and the Holden VZ S? Is it just the sports pack on it?
normal engine eg, exec has 175kw
and the SV6 engine upgrade has 190 kw
So is the S just like the Sv6?
The VY's had the s pac and that became the SV6 when the VZ's came out
Just to clarify, there was no 'S' model in the VZ series. The 'S' was replaced by the SV6 in the VZ. I am assuming you are talking about the limited edition SVZ series (based on the executive), which was released around Mar/Apr 06 with a few options. These vehicles had the same drive train as the normal executives ie. 172KW engine. Early VZ executives had 175KW until Dec 05. Hope this info helps. Cheers.
there was a s series but it was it ute's only,i only no this because i had one come into my work, it just a sporty model from the executives.
Check out my Svz
http://forums.justcommodores.com.au/...87-my-svz.html
Very early model VZ, possibly even a test variant!
Life starts at 200km/h
There were VZ s pack utes which i think from memory had a 175kw engine then Holden brang out a sv6 ute which had a 190kw in it.
