Results 1 to 9 of 9
Thread: duel fuel alloytec still hesitating only on gas
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    Default duel fuel alloytec still hesitating only on gas
    so this is the run down of my missus vz. its an exec wag alloytec on duel fuel dec 2006. 115k
    was driving fine, for the first few weeks we had it always running on gas, then she tells me it hesitated when taking off, i took it for a spin and floored it and it s&*t itself, "check powertrain" and ran rough....turned car on and off and its fine again.
    changed all 4 O2 sensors.....took it for a hard drive and was fine on both fuels even flooring it multible times, as was not the case previously. next day hesitating again.
    changed s/plugs bosch platinum gapped 1.1mm, a/filter, f/filter, genuine 10w-30oil and filter. cleaned throttle body and new intake gasket,sprayed gas injectors with throttle body cleaner when manifold was off, and disconnected battery for 30mins and pumped brakes 30 times(as instructed by forum member, to remove ecu memory...???)
    took for a spin drove real hard on both fuels and it was excellent heaps of power more responsive, goin great......next day missus tells me hesitating on gas, day later still hesitating and also "check powertrain.
    i took it for a spin and started stuttering or hesitating as soon as i put into drive after reversing out driveway, took off and still hesitating on and off flicked to petrol and gave it to it......PERFECT so now only running on petrol, WTF!
    Only thing i can think is that maybe blocked gas injectors, or cracked rubber hose that leads to injectors, as i had to bend them out the way to get coils off.
    or coils, but why does it still go good on petrol? really need help please
    also mainly seems to do it either taking off, or accellarating up from around 50km/h to 70km/h. went alright this morning from 80-150km/h on gas.
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    I know nothing about LPG set-ups ....... but can remember reading similar posts (might have been yours).
    Sounds like you need to find a friendly Holden Dealeship that is open, drive it hard to force the 'error' and without turning the engine off, drive straight back to the Holden Dealership to plug in a Tech2 & read the fault codes.
    Dec 2007
    nthn suburbs, vic
    after talkin to my cousin last night, beginning to think s/plug gap, as the s/plugs i removed clearly had a larger gap than the 1.1mm i put in.
    he said he's ea fairmont ran crap on gas until he changed the gap and it was fine. hmmmm
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Feb 2007
    The smaller electrode gap will make the engine run BETTER on gas than a larger gap.
    Have you checked the condition of the ignition coils? How's your battery holding up? Have you had the gas system recalibrated? Have you replaced the gas vapour filter every 20,000km? Have you tried performing an ECU reset after replacing spark plugs?
    Injected CNG, LNG & LPG: The only way to go better!
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by strgas View Post
    which brand of gas system is fitted ?
    BRC gas equipment is written on a few of the parts under the hood. i think it might be factory cos it says on the gas compliant plate. reg: "new oe". so prob wasnt registed yet. car was built in dec 2006 and gas compliant plate says installed 17-1-2007
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by poweredbycng View Post
    thanks for the reply mate, ignition coils appear ok, but dont know how to tell.
    battery is perfect its a deep cycle optima.
    from here on as pauline hanson would say"PLEASE EXPLAIN", recalibrated?, where is gas filter and can i change myself?, how do i reset ECU. cheers mate.
    kj0
    kj0 is offline
    VZ Crewman Cross 6
    Jul 2009
    Have you checked your sensors? Have you checked out the error code the powertrain is throwing at you?
    Feb 2007
    Quote Originally Posted by mattyr82 View Post
    The first thing to look out for is signs of spark leak, which shows up as white lines on the coil boots. Otherwise, you'll need to take the car in to a mechanic who has the appropriate equipment to test coils.
    The LPG system has its own computer that stores calibration data. In order for the system to operate most efficiently, it is recommended that the system should be calibrated once every 12 months.
    The gas filter is installed in-line between the vaporising regulator and the injector rails.
    To reset the ECU, just disconnect the battery for a few hours. You'll need to have your stereo unlocking code handy.
  1. which oil for my vz exec wagon on duel fuel alloytec
    By mattyr82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-04-2010, 04:25 PM
  2. VR 5L Duel Fuel Perfect On Gas, Stutters Badly On Fuel
    By djmenow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2010, 11:01 PM
  3. my vp duel fuel
    By nuskoolVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-09-2009, 11:07 AM
  4. VE & LPG... can duel fuel be done?
    By anonymousmoose in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-11-2008, 05:28 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
