Hey everyone.
How would i go about changing the transmision selector globe on a vz? Ive done it on my vs,but i don't know were to start with taking the trim of with this one. Also would it be a t5 globe?
any help would be appreciated!
thanks guys![]()
'Don't tell them your at a bar! But what else is open at night? ....It's a pornography store. I was buying pornography!.'
pinched this off another thread..It honestly only takes 5 minutes..The hardest part is trying to fit the light socket back into the original place.
"Drop the fuse panel and you will see 2 phillips head screws that attach the right hand console cover. The rear section clips in near the hand brake lever. Remove this panel and you'll see the light socket up there.
Phil "
Thanks To Phil
Sweet! Thank you
Do you know what type of globe it is?
T5 sounds familar
You probably already got one, but if you go to Holden, the part number's here
are the gear select letters meant to have a backlight on a vz
now : 05 VZ Berlina V6
had : 97 VT Berlina V6
before : 81 VH SL/E I6
