Results 1 to 2 of 2
Thread: vz control arm, radius/z bushes
    Vy Wagz
    Dec 2009
    Default vz control arm, radius/z bushes
    hi all,
    i need to replace these bushes, does anyone know if they are pressed in? easy to replace without vice/press in etc.
    i know the front should be fine, but the rear and top control arm ones look like they are pressed in?
    easy enough job on a weekend? then go get a wheel alignment?
    cheers
    Super Pro Front Triangle Bush kit for VT-VZ Commodore - eBay Other, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Apr-10 19:04:05 AEST)
    will this kit replace all 3 bushes? the large front one, im guessing adhustable castor? and the two smaller would be for the control arm near disck brake, then the other end attaching it to chassis?
    cheers
    vz wagon
    Aug 2006
    Wild west of Melb
    Its easier to do both bushes at the same time the rear ones are pressed in we used heat (oxy) on mine just be carefull of the linkpin as we burnt one of them so i had to replace that aswell and yes it will need a wheel alignment wen ya finished.
  1. Radius Rod bushes
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2010, 08:59 PM
  2. removing radius rod bushes.
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2009, 09:45 AM
  3. Radius rod bushes
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2009, 01:27 PM
  4. how to radius rod bushes
    By bradvt98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 10:20 AM
  5. Nolathane radius rod bushes
    By john41 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2007, 09:17 AM
