Results 1 to 9 of 9
Thread: wet floor
    vz exec / 10 ve ss ute
    May 2010
    Default wet floor
    any suggestions as to why my passenger floor soaks with water when it rains?i have poured water over the screen,door,the vent between the screen and bonet and over the airial but no water seems to be coming from any of these areas,does any one have any idea where else
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    wheel wells maybe...? at least that was the go with with the VLs.. water would leak in from under the wheel well on the left side because that's where the water sat on the road when it rained
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Check the inside of the door trim and the plastic sheet that covers everything. Mine had a couple of holes punched in it and water came in through the bottom of door trim and sill.
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    Quote Originally Posted by vy_storm View Post
    +1. Mine had come away from the door at the bottom. Used some silicone to re-stick it, but would be better off getting the proper stuff from an auto trimmer.
    I've also had an issue (while car was under warranty) of the front windscreen not being sealed properly which allowed a leak into the driver side footwell. now *that* took some tracking down!
    May 2010
    thanks for the feedback, i might get under the car with a hose this weekend,i poured a whole watering can over the windscreen seal and no water leaked in but in saying that over night if it rains the water makes its way in, frustraiting! hard to say when it started as it was garaged before the ss became family
    May 2010
    Quote Originally Posted by customvrss View Post
    from under the car? or aircon?
    where from tha a/c, i took apart behind the glove box and the foam padding was dry and the dust was undisturbed, is there anywhere else i should check?
    VE HSV GTS , VZ UTE, VL GROUP A
    Feb 2007
    are you sure its only when it rains i had an issue years ago with A/C Drain tube Blocked
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    a few months ago i had taken a car for a test run that had a sun roof. so decided to car wash it. after the deluxe car wash i returned the car. the sun roof never leaked. even the dryer on the car wash didnt show any holes or leaks. having another look at the car after this and i notice 2 inches of water on the back passenger side floor. i reckon the water came from the roof and down the B pillar and into the carpet. all this without seeing any leaks anywhere. i asked them to clean it up so we could try car wash again and they said no. dodgy seller trying to sell me a leaky car. maybe the roof join leaks on your car??
LinkBacks (?)
  1. 27-07-2011, 10:13 PM
  1. Crack in the floor pan
    By yehbudz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-12-2009, 11:47 PM
  2. wet floor!!
    By schteven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2008, 06:55 PM
  3. vr floor plans
    By badger__rox in forum Car Audio
    Last Post: 28-03-2007, 11:31 PM
  4. VS floor mats
    By Brycestro in forum Swap / Wanted to Buy / Trade
    Last Post: 08-07-2006, 01:19 AM
  5. sub in un-even floor in vs
    By crainy in forum Car Audio
    Last Post: 13-08-2005, 07:02 PM
