Results 1 to 6 of 6
Thread: Adventra Level-Ride Suspension
    VZ Adventra LX6
    Apr 2010
    Question Adventra Level-Ride Suspension
    I recently acquired a 2005 VZ LX6 Adventra and it has high-lift King Springs on the rear. The rear sits slightly higher than the front when there is no load on the back but I thought the Level-Ride Suspension would have evened it out. Can anyone enlighten me as to how the LRS works? Is it possible it is not working?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The level ride suspension uses air lift shockies to adjust the level.
    Unfortunately it only works to lift the suspension up when under load so in your case your springs are holding the suspension higher than the setting for the std height that the airlfts are set to.
    Even if you removed the shocks the car would still sit at the same height.
    When I replaced my air lift shockies in my senator with high performance gas shocks ( one of the airlifts was rooted and I don't like them anyway) the tail lowered about 10-15mm as the cars weight now sits on the springs not on the shocks.
    Hope that helps explain your situation.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VZ Adventra LX6
    Apr 2010
    VZ Adventra LX6
    Sep 2005
    That's interesting....as I just started looking into spring replacements for my '06 LX6. Reason is we went camping, loaded up the cargo space with esky, small bbq etc, hitched the camper trailer with it's ~110kg ball weight and noticed that the car didn't appear to level itself the way it used to.
    So the search turned up King springs (raised) with no "standard" option, so i suspect i'll get exactly what you have, westaussieadventra. A raised ride height? Not what i'm looking for.
    Lovells catalogue does list lowered, standard and raised, but interestingly doesn't mention the V6 model. I think i'll have to talk to them.
    Also, try finding shock absorbers......i hope i don't have to go back to Holden when they eventually need replacing.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by dugnvik View Post
    You may need to get Holden ones if you want to connect them to the level ride compressor as I'm led to believe the std Monroe air shocks have different connections although haven't actually found out for sure.
    ss
    Oct 2010
    Saudi Arabia
    I need some info on the 2009 Caprice & Commodore suspension. Can you fit the suspension from the Commodore on to a Caprice?
    Thanks
    Sami
  1. VS Senator Level Ride not working.
    By lethal SENATOR 185i in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2010, 03:50 PM
  2. VZ Adventra LX8 Suspension
    By nad19c in forum General Discussion
    Last Post: 03-08-2009, 07:23 PM
  3. lowering vt senator with level ride suspension
    By canabl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-07-2009, 04:38 PM
  4. Level Ride Fuse
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2009, 08:50 PM
  5. Firm up suspension in Adventra
    By wetwork65 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-09-2008, 08:29 PM
Tags for this Thread
