Results 1 to 6 of 6
Thread: VZ interior lights not working???
    VN SS
    Oct 2008
    Default VZ interior lights not working???
    hey people.
    i just bought a VZ acclaim wagon today. not realising till tonight that the interior lights are not working. it has the sunglasses holder at front and the two in the hand rails in rear. none are working at all. everything else lights up fine, even the glove box.
    globes are fine, i checked fuse and was fine, relay seemed fine. has 12v at fuse but nothing at plug behind sunglass holder.
    any ideas? the interior illumination relay felt warm. i swapped it with another of the same but nothing.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Have you check all connections going to each light housing.
    The 3 way switch at the front of the main light asm, is that switch on or in the middle position?
    Or you might have a wire touching metal where its shorted out.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VN SS
    Oct 2008
    ive only checked at the main centre light. there is no power at the plug behind it. but there is power at the fuse box under dash, the glove box light still works. the switch does nothing as ther is no power. the light around the ignition isnt working either but i checked and it has power there so its just a dud globe.
    as the fuse is still intact i cant see there being a short
    VZ Berlina LS1
    May 2009
    check the connection at the drivers pillar. there is a plug there which connects the roof wiring to the body wiring. i think its going to be a case of tracing the wires and checking for power. a wiring loom location diagram would come in handy here.
    VN SS
    Oct 2008
    thanks mate, i was gonna ask where the light joins to switches. ill check that now. diagram would be good
    VN SS
    Oct 2008
    there is power at the door switches. is the loom for the lights up the drivers centre pillar?
  1. interior lights not working when door is opened
    By mad_dog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2009, 09:40 PM
  2. interior lights not working
    By VTS07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2009, 01:39 AM
  3. interior lights not working
    By alokin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2008, 09:03 PM
  4. interior/boot lights not working
    By smith#29 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-11-2008, 06:52 PM
  5. All Interior Lights stop Working When Headlights turned on
    By GMTANK in forum Electrical Wiring / Questions
    Last Post: 30-08-2007, 11:24 AM
