Hey guys,
My vz has just ticked over 50,000km and this morning has begun to become really hard to open the drivers door handle...it seems wedged against or stuck against something, as it comes free there is a slight click/bang
when i pull the drivers door...it now struggles to open at all and makes that sound that happens when u have unlocked the car...and then press unlock again....over and over for about 20seconds :S
ive also noticed the inner door lock is not coming up all the way and can be pulled up manually from inside the car about 2-3mm when the car has been locked.
it is also now having trouble opening the door on the inside...
anyone had anything similar...
help would be greatly appreciated
thanks
i've had something similar happen,not in all of that sense
but i did have a clicking/banging noise when i would open/close the door or when i would drive.turns out the safety/protector strip on the side was coming off
have you had a look at that?
otherwise i wouldnt have a clue sorry
yeah well it seems to be very unusual..and on and off...
that all seems in tact...
its just when i pull open the HANDLE...it is essentially STUCK..and eventually gives with a big bang...
:S...
no idea then,then noise went away on mine eventually,but that was due to the strips being f-ed...otherwise no idea sorry
