Results 1 to 5 of 5
Thread: Abs fault flash on start up.
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Question Abs fault flash on start up.
    Over the past week I have been getting a very quick message on the dash only when cranking the engine over "ABS FAULT" only for a quick second then it's gone. I always for the first time of the day just turn the ignition to standby while it does a check and wait for the "OK" message then start the engine. Is it a glitch ? should I get it checked ? what can I do to check ?
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
    BANNED
    Feb 2010
    Quote Originally Posted by AussieHolden View Post
    My vz did it until i replaced the battery which was on way out never done it since.Try unpluging battery if its ok ,if not get a new battery
    May 2004
    Quote Originally Posted by amyb View Post
    I have already tried disconnecting the battery still get the same thing. Battery is only a year old ? RACV battery.
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    how far are you drives normally, might not be charging for long enough
    Chev badges are an instant fail
    VZ SV6 05
    Sep 2008
    hey buddy i had the same problem, probly around 3 months before my battery went (however my battery was about 4 years old), replaced and never happened again.
  1. vn v8 fault code 1 flash pause then 4 ?
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2008, 06:55 PM
  2. Fault Codes, VS won't start...
    By stevo-wagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2006, 07:32 PM
  3. VR - Wont start - fault with Security Key?
    By Smoken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2005, 02:40 PM
  4. how do you flash up the fault code for engine warning light
    By red phase down in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 03:03 PM
  5. how do you get the fault code to flash from the engine warning light
    By red phase down in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2005, 02:25 PM
Tags for this Thread
