Results 1 to 15 of 15
Thread: Whole Car Vibrating please help!!!
    07' VZ SVZ Ute
    Sep 2009
    Essendon, Melbourne
    Default Whole Car Vibrating please help!!!
    Okay heres my story... i brought a SVZ ute about 3 weeks ago and ive had nothing but problems! No need to bore the shit out of everyone by telling them all
    but the main problem i have is randomly the whole car starts to vibrate. can can be ideling or driving it will come and then go.. turning off the ignition doesnt stop the problem it will go away when it feels like it...
    seeing as i brought the car from a holden dealer i took it back... they couldnt even trouble shoot the problem because the car decided not to do it while it was with them..
    Holden reckon they checked everything suspension, engine timing, tailshaft, diff, and the list goes on.
    just want to know if anyone has the same problem and how the hell do i stop it before i blow up my car.
    Thanks guys any help would be awsome! so fed up with it spent more time in the work shop than behind the wheel.. definatly brought a lemon!
    mawsy is offline giggity giggity
    VZ SSZ UTE
    May 2008
    QLD
    any problems with the car take it straight back to who you bough it off, you get a statutory warranty with all cars purchased from a dealer so they are responsible for repairs, not yourself
    EDIT: within thirty days or something
    How much wood could a wood chuck chuck, if a wood chuck could chuck wood?
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    manual or auto...
    i wouldnt trust when they say they checked everything?
    "randomly the whole car starts to vibrate" - describe exactly what happens right before it vibrated last time?
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    If you have climate controll, it could be the A/C pump kicking in and out. Maybe the A/C pump is on its way out. Or already out.
    Or, check the wheel bearings. Jack one wheel up and try to rock it from side to side in the direction of the car. If it has lots of play, the bearing is rooted. They can be changed easily.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    tyre speration?????
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    Quote Originally Posted by VzVzVz View Post
    isnt the front wheel bearings one piece with the hub?
    and when trying to rock the wheel, left to right, doesnt that signify ball joints, and up/down mean bearings?
    VzVzVz's Avatar
    VZ S ute
    Jun 2009
    Port Melbourne
    Quote Originally Posted by impulsesv6 View Post
    Left to right rocking movement without the brake applied is the bearing. Ball joints and kingpins move when the brake is on. Anyway I had a similar problem where I noticed a vibration comming from the front wheel. I got it balanced, rotated tyres, but It turned out to be the bearing. The disk needs to come off to get to the hub bearing, but it's easier to take the three allan key bolts out first and whack the hub out of the disk with a hammer. Not a big job. But a bearing will cost about $140 from an auto parts store.
    07' VZ SVZ Ute
    Sep 2009
    Essendon, Melbourne
    impulsesv6
    it is a manual.. the last time it started to vibrate i was cruzing along at 70kms and it started. no heater on, no a\c. not even the radio turned up there was no warning at all. it comes and it goes when it feels like it.
    it will also do it when the car is ideling. so i doubt its a wheel bearing. the vibration is as if there is a jack hammer in the tray.. but the vibration is equally distributed through out the car. if that makes any sence.
    thanks for every one help. it did it again today on the way to work..
    VE HSV GTS , VZ UTE, VL GROUP A
    Feb 2007
    VZ Adventra SX6
    May 2009
    I have the same issue (i think) with a VZ Adventra.
    I get between 90 - 115kph and a get a bad reverberation/vibration through the car and it seems coming from the front, and if the car is under cruise control, you can feel the cruise control apply a bit more power to keep it at the speed. So what ever the cause, it is interferring with the running of the wheels
    Does this sound like your issue??
    I have been fighting the dealer ship for over 2 years with this issue (lucky I have 6 year warranty) but of course they wont even do a test at the location or under the conditions it occurs.
    If I get anywhere, I will post what they find (if ever they do anything)..
    07' VZ SVZ Ute
    Sep 2009
    Essendon, Melbourne
    I finally worked out the issue today!! I THINK?
    Its actually the thermo fans. one doesnt kick in and its as if the other one try to take the power of the two can into one. the fan works so hard it looks like its gonna take off.. i rung holden today and they are going to fix it monday.. rbo135 i recommend you try letting your car get at running temp then put the air con on fully and pop your hood watch them thermo fans..\
    hopefully after monday the problem is solved ill let you know how it goes.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    thermo cant shake that much can it?? and the advenutra is wheel balancing buddy
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VZ Adventra SX6
    May 2009
    Quote Originally Posted by J@m3$ View Post
    interesting... at one stage i thought it might be the fans.. Thanks for the tip, J@m3$, i will certainly try that.. Tried everything else.
    Rob
    VZ Adventra SX6
    May 2009
    Quote Originally Posted by vn_v6 View Post
    Wish it was simple as wheel balancing, but it has had the wheels balanced a lot, both by Holden Dealership and an independant, and the problem doesnt get better or worse on each balance..
  15. #15
    07' VZ SVZ Ute
    Sep 2009
    Essendon, Melbourne
    The thermo looks like its about too take off and fly outta the engine bay hahaha! im just convinced i brought a dud of a car. today my central locking started playing up! FFS!
  1. Vibrating when driving
    By Michael_123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2010, 06:14 PM
  2. Vibrating
    By skinnyscotton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2008, 07:56 AM
  3. Little Help: Surging / Vibrating
    By Necrum_McDirk in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 10:07 PM
  4. Vibrating car
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 05:16 PM
  5. Vibrating VS.....HELP im going nutZ
    By ghostVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2004, 08:41 PM
