Results 1 to 7 of 7
Thread: coolant change
    vz executive
    May 2010
    newcastle
    Default coolant change
    for my vz v6 alloytech motor should i use tap water or deionised water?
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    You can use whatever you like. There are no laws or restrictions on what to use.
    I only use demineralised water in my cooling system.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Quote Originally Posted by benboy View Post
    there are no laws or restrictions on what to use.
    Wtf?!@?%$!
    To the OP, normal or distilled water either on is fine.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    VS Exec 5spd
    Aug 2008
    technically you should use distilled water or pure water as the minerals in tap water can lead to corrosion.
    VZ SENATOR
    Mar 2009
    LOL, no laws about what water to use..
    Cop pulls you over, "Hi mate, just wanted to see if I could check your radiator please"
    You, "How come?"
    Cop, "I need to make sure your not running any tap water in there, it's against the law!"
    05 VZ Berlina
    Mar 2010
    Quote Originally Posted by mattsv6 View Post
    You, "Go ahead - just unscrew that cap..."
    now : 05 VZ Berlina V6
    had : 97 VT Berlina V6
    before : 81 VH SL/E I6
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by Benboy View Post
    Bwahahahahaha You plonker! Also make sure you run recycled air in your tyres as the EPA will bend you over if they catch you with dirty air......
  1. Coolant change
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-08-2010, 07:22 PM
  2. Coolant change or not in a VC 202...
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-03-2010, 02:17 PM
  3. Coolant change SV6
    By diysv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2010, 04:02 PM
  4. coolant change.
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2007, 04:32 PM
  5. coolant change
    By KIKE in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-06-2006, 08:48 PM
