Results 1 to 14 of 14
Thread: problems with new exhaust on VZ sv6
    VZ SV6
    Jul 2009
    Default problems with new exhaust on VZ sv6
    posting on behalf of a mate.....
    he recently got a 2 1/2inch cat-back exhaust put on his VZ SV6.... basically, now it runs a bit strange, gear changes are a bit off and when in P or N he cant rev his car over 4000rpm, it has a cut.....
    Does anyone know why this is? Im guessing he'll need a tune/re-map for the exhaust...or is there some other way? reset ECU, etc?
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    try disconnecting the battery for 10 minutes (neg terminal) this usually fixes some computer problems after installing aftermarket parts
    Life starts at 200km/h
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    The cars computer will limit revs to 4k in neutral or park. I would try disconnecting the battery for 10 as suggested above, this will not allow you to rev it past 4k but it should reset the cars ecu paramaters and allow it to re-learn them with the new free flowing exhaust.
    (Or you can get it tuned if you want )
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The ECU doesn't learn anything, it compensates. The shift points would have changed in the transmission due to the different exhaust.
    A 2 1/2" single is not the right exhaust for the SV6, IMO. I would have gone a twin, or the one that I recommend is the 2 1/4" twin into 3" single.
    The revving issue is normal.
    Visit my Facebook page
    az_sv6's Avatar
    az_sv6 is offline coudnt aford a v8
    vz sv6
    Sep 2009
    western sydney
    Quote Originally Posted by Not_An_Abba_Fan View Post
    not_an_abba_fan you've been pushing this 2 1/4" into 3" for ages now. i think i have to look into it.
    Black VZ SV6
    Dec 2005
    NAAF - Twin 2 & 1/4 into 3 is what i have, and that shiz is the mad note!
    Really cuts the highway drone down too! (i have had 3 different exhaust configurations now, and this is definitely best)
    Just curious, why do you want to rev is past 4k in P or N anyway?
    Drive it
    Like ya stole it!
    2005 VZ Alloytec 175 wagon
    Feb 2010
    Portland VIC
    so after fitting new exhaust you have to get the car retuned to get the most out of it, or can you just disconnect the battery for 10 mins like someone said up further and that will fix any problems.? if needs a tune how much roughly does that cost?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Disconnecting the battery just resets the PCM back to factory defaults.
    To get the most out of any car you need to tune it, but by just fitting the exhaust it will give you a godd noticeable improvement.
    Feb 2010
    Portland VIC
    i got a 2 1/2 cat back exhaust with hotdogs fitted the other day, since been fitted it now has an aweful drone at about 1800rpm at about 100km/h which is the worst for cruising and is driving me insane. is there any way to fix this problem without removing my new exhaust?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    In short....no.
    carless for now
    Feb 2007
    perth,Western Australia
    Feb 2010
    Portland VIC
    it has one muffler right at the rear. so your saying another muffler somewhere along the exhaust will quietenthe drone down a bit. but will it still give it a note or will it be as quiet as the stock exhaust?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It will make it quieter and a bit deeper, but would still drone. If the resonator on the rear and a hotdog on the front doesn't shut it up, a bigger muffler on the front won't either. The configuration you have is the best for the earlier V6's but clearly doesn't work on the VZ.
    Feb 2010
    Portland VIC
    what do you advise as the best set up then? the bloke from the zrst joint said that he was going to put a 2 1/4 on it and then got under the car and said that a 2 1/2 would suit my wagon better for some reason. he also said that he hasnt come across a car with that setup that has droned before....so yeah im open to suggestions to go back to him with.
  1. Problems With Exhaust
    By ::Team420:: in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2009, 10:58 PM
  2. Exhaust problems
    By MikeysVR24 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2008, 04:17 PM
  3. Exhaust Problems - VT
    By holden09 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2006, 12:10 PM
  4. Exhaust tip problems
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2005, 07:37 PM
  5. Exhaust problems
    By Baldric in forum General
    Last Post: 02-06-2004, 12:04 PM
