Results 1 to 22 of 22
Thread: Air filter for vz calais
    VZ calais
    May 2010
    Default Air filter for vz calais
    hey guys whats a good air filter that would fit here ?
    Attached Thumbnails Attached Thumbnails Air filter for vz calais-img_0053.jpg
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Dec 2009
    Quote Originally Posted by Haydn View Post
    The standard one you buy from Holden or Ryco equivalent however it's up to you if you want to pay a lot for a K&N and then have to clean and oil it for no real gain. Cost of a K&N would cover genuine air cleaners probably longer than you will keep the car unles you drive through a lot of dust.
    VZ calais
    May 2010
    hey guys i mean like getting a pod filter for it not just the actual filter ??
    Dec 2009
    the standard air cleaners are good air cleaners better than pods if you ask me I'd leave it the way it is.
    VZ calais
    May 2010
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    I wouldnt bother with the pod, there heat traps.
    Do a search for 2 Hole mod. All it involves is cutting a second hole in ur airbox.
    The Blue One
    Quoted for truth
    VZ SV6
    Dec 2009
    Ballarat
    BMC. $10 more expensive than the K&N form Autobarn, but better flow properties. And yes, definately do the 2 hole mod
    I just love the way other motorists on the highway think it's an unmarked cop car.........
    And Yes, it is a manual
    VZ Calais
    Jul 2009
    there are a few tests out there that show the amount of crap going thru the filter and into your engine... just a get a genuine one - they flow well and filter out most of the crap
    dmar's Avatar
    dmar is offline kl
    vz
    Mar 2008
    looking to replace my panel filter as well, seeing as though i havent done so since those hectic dust storms last year, whats the rough price on a gmh or ryco replacement?
    also, do you guys clean your maf sensors when cleaning/replacing air filters and if so, what do you use?
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Don't put a pod in. it'll just suck hot air in from the engine bay and not really do much in terms of performance. Plus, they look silly. Just whack a K&N panel filter in the origional air box for a bit more grunt and noise.
    VZ calais
    May 2010
    VZ calais
    May 2010
    2005 VZ Alloytec 175 wagon
    Feb 2010
    Portland VIC
    about 100 on ebay...but you gotta make sure you get the right one for you...like year of your car, coz there is a few different shapes. im after the same for my wagon but not sure what number it corresponds with that will fit it...any help would be good, i got a 05 vz 6cyl wagon...cheers
  15. #15
    VZ calais
    May 2010
  16. #16
    PaulSV6's Avatar
    Jun 2008
    Castle Hill
    Quote Originally Posted by PaulSV6 View Post
    Click on the above link, i got mine for $70, so shop around.
    The Blue One
    Quoted for truth
  17. #17
    Feb 2010
    Portland VIC
    looking at doing the 2 hole mod and putting in k&n filter aswell.....just curious though, with the 2 hole mod, without the second pipe (meaning just cutting the hole) does it suck in hot air. and do your really need to get a monaro thingo or can you do without it. ive read alot of those posts and wasnt too clear. and so the k&n filter gives it a bit more noise?
  18. #18
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Oiled filters are not worth the effort IMO. Any increase in flow is negligible (you're lucky to get an extra 2rwkw), they filter a lot worse then the standard paper filters, and the oil can play havok with your MAF. This is why you don't see oiled filters standard on many cars if any.
    Two hole mod also has negligible increase in flow but does make more induction noise which may or may not be what you are looking for.
    Stick to the standard paper filter, clean it with compressed air regularly and replace it every 12 months, or less if you drive on dusty roads.
  19. #19
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by TMM View Post
    Less or more if driving on dusty roads? im pretty sure you mean more, as in more regulary (every 3 weeks)
    AFAIK the 2 Hole mod has found to be the most beneficial of all CAI. If only we could get mafless!
    Life starts at 200km/h
  20. #20
    Feb 2010
    Portland VIC
    fitted the k&n filter about 4 hours ago. havent really noticed any difference. maybe a bit at 3 grand but yeah...nothing to rave about. i didnt clean the maf sensor though. does that matter? and i still thinking of doing the 2 hole mod but dont want to cut the box up. can you just get away with removing the snorkal? does that have the same affect?
  21. #21
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    If you aren't keen on cutting up the air box, get yourself a second hand one or one from Holden. Seriously, I'm not a tradie but I did this one Saturday morning pretty easily.
    I wrote a how to for it and you can see its pretty easy. One thing I will add, if you decide to add the MCAI, it will need trimming, and I have those details on the how to also.
    Back to the filter, I've got a K&N and while its a pain to clean it, when you don't over oil it, leave it overnight in the shed to settle, and stick it in your own customised air box on a crisp sunday morning and you give it a bootful on the open road and hear that induction roar, its worth it.
  22. #22
    Feb 2010
    Portland VIC
    yeah lad, might have to do it down the track. not in any great rush to get it done. but from what i hear its well worth it. have you got a vid of your car with it on it for the sound? and nice write up by theway lad, looks fairly straight forward.
  1. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  2. installing a pod filter on a stock vk calais
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2006, 03:36 PM
  3. airpod filter on vk calais
    By Owen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2006, 08:42 PM
  4. Air filter 4 VR calais
    By Joey_21 in forum General
    Last Post: 12-01-2006, 02:05 PM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
