Results 1 to 5 of 5
Thread: Central locking issue
    05 VZ SV6
    May 2010
    Default Central locking issue
    Hey guys and gals,
    I'm having an issue with the drivers side locking on my VZ SV6. When i go to unlock the car via the remote the car unlocks, however the drivers door doesn't completely unlock. You can hear the mechanism repeating to try and properly unlock it. So to open it i must reach through the back door and flick the switch up. Then opening the door sparks the alarm. Also while it is stuck the central locking wont lock as the door is trying to unlock itself.
    Anyone had a similar issue? Is it an easy fix?
    Thanks in advance
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    The door actuator maybe stuck, take the door trim off & see if u can free it up by using some WD40 or silicon spray
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    white vz 2006
    Nov 2009
    i had similar problem more than likely solenoid is not working. easy to adjust or replace let know how u went
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Mine just started to stick a little today. Anyone know the costs to get the solenoid replaced?
    white vz 2006
    Nov 2009
    you have to buy lock and solenoid together about $165 from gmh
  1. VN central locking issue
    By tamass08 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2010, 04:41 PM
  2. Central Locking Issue
    By AL'sVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2007, 11:24 AM
  3. Vr Central Locking Issue
    By vrbenno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2007, 06:07 PM
  4. Central locking Issue
    By vincent49 in forum Electrical Wiring / Questions
    Last Post: 07-02-2006, 07:51 PM
  5. central locking issue
    By Insanesinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2005, 09:32 PM
