Results 1 to 8 of 8
Thread: Speeo probs
    BAM BAM 11's Avatar
    BAM BAM 11 is offline BAM BAM11
    vz one tonner
    Dec 2009
    Kangaroo Island
    Default Speeo probs
    HAVE A PROBLEM WITH A SPEEDO AND ELECTRIC SPEED SENSOR AND TRIP COMPUTER,DRIVING ALON IN VZ ONE TONNER AT 100 KS ON CRUISE[MANUL SPEEDO] AND MY SAT NAV IS TELLING ME I AM DOING 96KS AND THE ELECTRONIC SPEED DISPLAY IS SAYING 94KS.
    ANY HELP WOULD BE GREAT !!
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Unplug your cars battery for 10 minutes, plug it back in and see how it is then.
    Also, have you changed your wheels by any chance?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Get the PPK set in the cluster to your car - if you have changed the wheels/tyres
    and 3 Dangerous non ABS VN's
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    I know that standard from factory the speed readout is offset by a few km/h. Normally when travelling at an indicated 100 km/h, your actual speed will be 96-97, so that sort of sounds about right.
    I have noticed that the speedo and electronic speed display seem one or two clicks out.
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    I had the VZ Clubby and had the same problem!
    I thought it may have been lag in the digital display. My digital display would display the correct speed but was a bit slower to display it
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Most, if not all newish cars are a few percent out on the speedo. The reason they do that is it is illegal for the speedo to show a speed less than what the vehicle is travelling, so by making the speedo show more than the speed the car is going they are safe.
    I would trust the GPS for the most accurate speed display. However if you want to change the speedo there is a little kit from jaycar that can adjust your speedo, called a speedo correction kit, funnily enough.
    BAM BAM 11's Avatar
    vz one tonner
    Dec 2009
    Kangaroo Island
    Thank you all for your comments and appreciate your help,will let you know what the problem if any is once i have done what you guys sugested.
    CHEERS
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Don't yell mate, we can hear you clearly . (Sustained use of CAPS is considered as shouting.) Turn your CAPS lock off.
    Nothing unusual about your speedometer 'problem'. All new vehicles must have a spedometer output that indicates the actual speed is higher than that being travelled. Check with your dealer and they will tell you that 2 - 3 km/ph fast is acceptable. I guess this has come about because so many drivers think they can travel above the speed limit because there is a 5 km/ph (or whatever) tolerance before Police will enforce law. Not so. I know several people who have been pinched for 2 km/ph above speed limit. How do you 'beat the system' ? Don't exceed the speed limit(s).
  1. A few probs...
    By tombomb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2009, 10:39 PM
  2. car probs
    By dave20089 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2009, 05:00 PM
  3. ABS probs
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2009, 12:50 PM
  4. AUX probs (4 on amp 2 on H/U)
    By bass_master in forum Car Audio
    Last Post: 06-02-2007, 03:49 PM
  5. !! a few probs with my VT !!
    By chris87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-03-2005, 07:00 PM
