Results 1 to 6 of 6
Thread: Worn driver side strut mount
    2004 VZ Calais 190Kw
    Dec 2009
    Penrith NSW
    Question Worn driver side strut mount
    Just a question for the guru's.
    I just had a pink slip inspection (RWC) done on my 10/2004 VZ Calais which has just clicked over 100,000 km's. They passed it but said that the right (driver side) strut mount was worn and producing up & down movement in the right front wheel.
    Apparently, it is supposed to be a relatively simple job to replace the strut mount, but that it would need a new bearing as well. Common sense says if you did one side then you'd do both.
    My question is considering the wear & tear, would it be more prudent & cheaper in the long run, to replace the whole strut (incl mount & bearing)? Also, should I tick with Holden parts or is there a better aftermarket strut that can be used that may be cheaper?
    Cheers.
    Dec 2009
    Penrith NSW
    I'm surprised not to have had any responses to this suspension question about strut mounts or found a link in FAQ's.
    I'll just have to do some more hunting around some suspension places.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    If it isnt broke, why fix it. Just pull the strut out and replace the bearing and the mount. Unless the strut has failed, then you can go about looking into replacing it.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Hot House VY SS
    Jan 2010
    Personally I'd replace the struts too, esp as your car has done 100kms its likely they are still the originals and probably getting worn. Check the GSLRallysport forum, he does KYB excel shocks for around $150 each, which will be a lot better than genuine. I'd stick with genuine strut mounts and bearings though, I priced some up for my VY a while back and are around $70 a side complete.
    Basically by doing both at the same time you are saving the labour and the cost of a wheel alignment if you had to do say the struts later, which is essentially $300 right there.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    After 100,000k ur front struts will definitely need replacing.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Dec 2009
    Penrith NSW
    Thanks for the feedback guys. I went to Holden today for some advice.
    They indicated if I was happy with the firmness of the ride then to stick with original Holden strut mounts. The tech advisor indicated that aftermarket mounts can stiffen the ride and some brands don't last too long before they flog out. My choice.
    I figured that they've always pointed me the right way in the past so I left it with them. I also told them if it needed new struts to stick them in.
    Well, it turned out the struts were fine, smooth movement & no leakage. Got out of it for a couple of hundred dollars and no risk of spring compressors leaping off & belting me in the head.
    They kept the old ones to show me and they had certainly collapsed internally. Steering is now tight & firm like it was when I first got it.
  1. How to remove driver side button for side mirrors?
    By SupremeVT98 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-07-2009, 09:14 PM
  2. strut mount...not happy!!!
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2008, 07:47 AM
  3. WTB: VS V8 Driver Side Eng Mount Bracket
    By PREDATR in forum Swap / Wanted to Buy / Trade
    Last Post: 22-03-2008, 04:25 PM
  4. Qwik strut mount question.
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-05-2007, 12:05 AM
  5. Broken boot lid gas strut mount
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 09:30 AM
Tags for this Thread
